Results 2,171 to 2,180 of 2348
April 29th, 2015 11:45 PM #2171
Namamatayan ka kahit warm-up pa lang. Sa akin kasi kapag less than 3.minutes warm-up ko namamatayan ako kahit nabiyahe ko na din ang sasakyan.
Nagsearch ako sa net and one of the problem na malapit na malapit sa symptoms ko ay yung leak daw sa topmost gasket sa injection pump. Puwede papalitan yan pero matrabaho. Square yung gasket at hindi o-ring type. Pero may solution na simple. Put engine oil stop leak sa fuel tank. Same ratio as with 2t oil. 5ml for every liter. Seems to be working for me after 3 days of use. Pero usually mga 1week daw marerejuvinate ang seals na makunat na kay nakakapasok hangin. Read ka dun sa pajero thread natin. Hehe. Baka makatulong.Fasten your seatbelt! Or else...Driven To Thrill!
- Mar 2014
- 901
April 29th, 2015 11:49 PM #2172Check your fuel hose lines muna. Baka may maliit na butas o may crack o may maluwag na hose clamps.
Sent from my Starmobile UP+ using Tapatalk
April 30th, 2015 10:05 AM #2173
- Sep 2006
- 1,335
May 5th, 2015 01:51 PM #2174Remove black fuel hose between fuel filter and injection pump.
Replace it with a clear transparent hose.
Start engine to check for air bubbles on this clear hose.
- Apr 2012
- 5
May 12th, 2015 06:11 PM #2175Hi Boss Dieseldude,
I'm experiencing a humming noise at 2,000 RPM while running. It sounds like an electric motor, noise is constant at 2,000 RPM. It's not that loud though, i can only hear it when i'm traveling at night. I don't experience loss of power. What could probably cause this? Engine is 2KDFTV. Thanks, Boss!
- Aug 2013
- 475
May 13th, 2015 02:46 PM #2176
- Sep 2006
- 1,335
May 13th, 2015 10:57 PM #2177
May 14th, 2015 05:32 AM #2179
Fuel filter ️Sir ... Baka madumi na fuel tank mo.. Kaya recurring ang problem mo..
May 14th, 2015 06:48 AM #2180
Ni-set aside muna namin yun problem for a month kasi inayos muna namin yun power steering lines. Now that ok na yun steering ng sasakyan, ito na ang next namin na tututukan.
As of last Tuesday, same problem pa rin. Nagdecide kami na dalhin ko yun sasakyan sa CDC once magkaroon ako ng free time. May hinala na rin kasi kami ng erpats ko na injection pump problem na ito.
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
