[QUOTE=Djerms;1921600]Sir I meant this post. ^_^ Thanks in advance.
Hi Dieseldude,
Last month I had jerking problems with my strada but after a few re-fuels it miraculously went out on its own. I'm guessing I had a case of a bad refill which, when I re-fueled from another station diluted the contamination. My dilemma is that I recently replaced fuel filter and only ran 1,500kms on this new item. This was also the time frame when the jerking occurred.
You think I should change to a new fuel filter again since maybe contamination is in the fuel filter? I am worried if there is, it might get sucked by the injectors. Or should I let it be and just change after another 3.5kms? (i normally change every 5tkms) kasabay ng oil change.
The strada is running fine and very good now after 2 full tanks from another station.....
Many thanks and more power!
There is no need to replace the fuel filter if it is original.
