Results 1,351 to 1,360 of 2348
- May 2007
- 106
June 18th, 2011 07:53 PM #1351
June 19th, 2011 10:49 PM #1352
good day sir dieseldude,
hingin ko po sana expert opinion/advice nyo regarding increasing the boost of 4d56tdic engines by putting washers underneath the wastegate actuator can, as per initiated by our respected tsikot top members..
i personally installed the modification on my ride (95 pajero local) and power difference is very much noticeable..
eugene
June 19th, 2011 11:06 PM #1353
is this safe for the engine sir?
any negative effects?
thanks in advance..
- Sep 2006
- 1,335
June 21st, 2011 10:10 AM #1354
- Sep 2006
- 1,335
June 21st, 2011 10:19 AM #1355
June 25th, 2011 11:44 AM #1357
Sir Dieseldude may I ask what would happen if you would pre-heat the diesel fuel before it enters the injection pump? Any benefits or bad effects?
- Jan 2005
- 445
June 27th, 2011 12:08 AM #1358Toyota 2C
Normally aspirated
A mechanic has replaced the water pump unfortunately there are no timing marks on the cam, injection or crank pulleys.
After the assembly, the engine took some time to start (run at idle for a few minutes then turned off the key). After the mechanic left It is still hard to start and it died. My brother filled the tank with one gallon of diesel. then it started but there is some terrible noise as if an injection noise or a high pitched metal noise.
Actually I left the mechanic with my brother and never witnessed the first or second start ( I had something important to do).
Is our camshaft or piston or valved already destroyed?
How do you time a diesel without ,markings?
What shall I do now? Thanks in advance..
Read more: http://tsikot.com/forums/engine-fuel...#ixzz1QOXcmb6J
- Sep 2006
- 1,335
June 28th, 2011 06:39 AM #1359
- Mar 2004
- 13
June 28th, 2011 08:22 AM #1360sir
just would like to know kung saan pwede magpacalibrate ng direct injection engine. sabi kasi sa akin pa calibrate ko daw ang injection pump ko... any place you know near cavite area lang po sana..
thanks
VinFast VF 3
