Quote Originally Posted by Dieseldude View Post
Hi Dieseldude,
No idea. I don't have the air flow specs of both Toyota and K&N. In the absence of specs, you can't go wrong on original.
If the K&N air flow specs match or exceed Toyota's, and if your cost comparison is correct, K&N would be a good alternative....
Thanks..... You're welcome...
Dieseldude,
Many thanks. That is exactly what I'm looking at, the specs of the original against that of K&N.
On another topic, I'm a bit worried about these DENSO Common rail system failures. Do you have statistics (Year Model against Number of cases you have attended to). Will the possible defects result to a significant danger when driving? PM me please if the answer is sensitive.
