Originally Posted by
nissan_D21
Sirs Dieseldude and bennisiozo,
Maybe valve clearance adjustment is the first one that i will go for, its been 40,000kms since last adjustment, by the way sirs the engine ran 280,000 already but rebuilt at 210,000, liners pistons and rings, bearings,valves and guides and injector nozzles.All are oem parts exept for the pistons. If valve clearance adjustment is not the solution, i will have the injection timing checked, then test compression. I just hope it is the solution, or its the inevitable engine overhaul.
thanks guys! Big Help!
