Results 51 to 57 of 57
December 6th, 2007 12:52 PM #52
December 6th, 2007 01:39 PM #53
Sa battery I very much consider the number of plates inside, the more the better. Dito sa atin the most is with 11 plates in each hole. hope magkaroon ng 13 plates. Outlast exceed and the motolite excel are among those (24 mos warranty) Next is with 9 plates like motolite enduro, gold and outlast xdr etc. (usually with 15-18 mos warranty) then the ordinary with 7 plates, normally ito yung with 12 mos warranty (dati nga 6 mos lang) and includes the non maintenance free and some maintenance free types.
Yep sobrang mahal ng battery nowadays, yung dating 2k+ na 2sm premium nasa 4K+na! kaya yung mga 3sms it will range from 5-6K sa mga leading brand.
January 14th, 2008 08:04 AM #54
Sobra na ngang mahal ng batteries ngayon. And when they die, they die suddenly,- with very little warning........ Hindi katulad ng mga batteries noon....
Kaya nga, some people who I know, change their batteries every 18 months just to be sure...
Ako,- I basically wait for telltale signs.... Kung medyo may kaunting palya or anything na out of the ordinary sa start sa umaga and more than 18 months na ang battery,- I change battery on that day....
AFAIK, mas mataas ang rating in terms of AH ng 3SM vs. 2SM. So, as you go higher/bigger, the capacity of the battery to deliver current/power over a period of time also goes higher.... For example, a 50AH battery can deliver an Ampere of current for 50hours; or 2 Amperes of current for 25hours and so on.... A battery, theoretically can deliver very high current...
5101:pcwhack:
January 23rd, 2008 03:13 PM #55
According sa Powerbuilt Lucena, MOTOLITE Dealer dito sa amin e hindi daw compatible ang MOTOLITE sa Korean made cars. Kaya nung bumili ako ng battery sa kanila e nilagay nila sa resibo 18 months warranty lang vs. the original 21months warranty. Kaya next time etry na ako ng iba battery para sa STAREX namin. Ang reason nung may-ari ng POWERBUILT e dahil daw malakas kumarga ang KOREAN CARS.
January 24th, 2008 06:51 PM #56
I just changed to a Motolite Gold 3SM (Php5k) for my Starex late December. My previous battery was the same brand and lasted 23 months. Sabay na rin ako nagpalit ng brand new replacement alternator (Php6k) dahil nasira na pala ang IC when they opened it kaya hindi na nag-cha charge up to 14v. Everything went well since then, Para ngang lumakas pa ang hatak. But last Sunday, just barely a month after, ayaw na sya magstart. May konting redondo lang. Haven't had time yet to have an electrician look at it. Pero bakit ganun?! Defective battery ba o defective alternator? Both naman are under warranty pero bad trip lang. I just hope the shops honor the warranty with no hassle. Any ideas why this happened? TIA.
February 23rd, 2008 02:28 PM #57
I used motolite gold maintenance free for my pregio, and this battery will last up to 3yrs or more kung maganda ang battery compartment mo. its expensive pero no head ache naman. mas mahal pa ito sa battery ng expedition. have your alternator output and load regularly check.
Specs, prices, features: Everything you need to know about the all-new Hyundai Kona | TopGear PH...
Hyundai Kona (2nd Gen)
