Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
    Nov 2004
    #41
    I bought Dyna Power maintenance free calcium battery for my pajero.. 3sm sya i think..
    Made by Mercury..
    Price is 3,000 less P500 for the trade in.. so P2,500 nalang
    Apr 2004
    #42
    the new GS batteries are "tropicalized", i'm using them now coz they are cheaper than motolite's.. if it lasts 2 years then i'm good with it.
    Jan 2004
    #43
    Quote Originally Posted by the_possessed View Post
    Made by Mercury..
    same here, i also use dyna power. pero parang less than 2.5k ko siya nakuha. might be the other variant.
    Apr 2006
    #44
    Saan nakakabili ng Dyna Batts...I also need a 3SM for my rig. Thanks mga bossings!
    Feb 2005
    #45
    Just bought outlast 2SM battery (color blue) for my innova with 15 mos warranty for 3700 less 550 for trade in of old one for net of 3150. Is that price alright already?
    WBR,
    #46
    does battery for diesel engines will work perfectly with gasoline cars. Bigay sa akin ng Outlast retailer is outlast exceed battery, then notice ko may diesel na nakasulat. ok lang ba yun?
    Jun 2006
    #47
    Quote Originally Posted by wool View Post
    Ok yan, no problem. Its basically the same battery. Only difference is battery for diesels are heavy duty. Diesels need more juice to crank the engine.
    Jul 2003
    #48
    for outlast batteries, will the price be lower (kahit a couple of hundred pesos) sa main office nila sa n.domingo vs other dealers?
    will switching back (due to money restrictions) to a 2sm from a 3sm have any negative effect in the life of the battery or the vehicle (2004 dmax)?
    casa orig 2sm lasted just over a year. current 3sm motolite is still working at 2yrs and 4mos but parang mahina narin coz pag naka hazard or mag switch on, malakas na mag dim momentarily display lights. i think some reported their original 2sm battery lasted 2 years even for a diesel engined vehicle.
    thanks
    Jun 2006
    #49
    Quote Originally Posted by kurt View Post
    thanks
    Pareho lang yata ang price. If 2sm is the original battery, then it should be good enough. I think, the life of a battery depends more on the price and materials used than the size.
    Aug 2006
    #50
    Nasa magkano na ba inaabot ng Motolite Gold ngayon?
    #51
    did i read right? 6K na ang outlast 3sm????
    Mar 2005
    #52
    Quote Originally Posted by Innova_Boy View Post
    WBR,
    Sir, now lang po kayo nagpalit ng battery since you got your car?
    It sure lasted long sir!
    No idea on the price but am sure di ka naman lugi in your purchase...
    #53
    Sa battery I very much consider the number of plates inside, the more the better. Dito sa atin the most is with 11 plates in each hole. hope magkaroon ng 13 plates. Outlast exceed and the motolite excel are among those (24 mos warranty) Next is with 9 plates like motolite enduro, gold and outlast xdr etc. (usually with 15-18 mos warranty) then the ordinary with 7 plates, normally ito yung with 12 mos warranty (dati nga 6 mos lang) and includes the non maintenance free and some maintenance free types.
    Yep sobrang mahal ng battery nowadays, yung dating 2k+ na 2sm premium nasa 4K+na! kaya yung mga 3sms it will range from 5-6K sa mga leading brand.
    #54
    Sobra na ngang mahal ng batteries ngayon. And when they die, they die suddenly,- with very little warning........ Hindi katulad ng mga batteries noon....
    Kaya nga, some people who I know, change their batteries every 18 months just to be sure...
    Ako,- I basically wait for telltale signs.... Kung medyo may kaunting palya or anything na out of the ordinary sa start sa umaga and more than 18 months na ang battery,- I change battery on that day....
    AFAIK, mas mataas ang rating in terms of AH ng 3SM vs. 2SM. So, as you go higher/bigger, the capacity of the battery to deliver current/power over a period of time also goes higher.... For example, a 50AH battery can deliver an Ampere of current for 50hours; or 2 Amperes of current for 25hours and so on.... A battery, theoretically can deliver very high current...
    5101:pcwhack:
    May 2005
    #55
    According sa Powerbuilt Lucena, MOTOLITE Dealer dito sa amin e hindi daw compatible ang MOTOLITE sa Korean made cars. Kaya nung bumili ako ng battery sa kanila e nilagay nila sa resibo 18 months warranty lang vs. the original 21months warranty. Kaya next time etry na ako ng iba battery para sa STAREX namin. Ang reason nung may-ari ng POWERBUILT e dahil daw malakas kumarga ang KOREAN CARS.
    Jul 2006
    #56
    I just changed to a Motolite Gold 3SM (Php5k) for my Starex late December. My previous battery was the same brand and lasted 23 months. Sabay na rin ako nagpalit ng brand new replacement alternator (Php6k) dahil nasira na pala ang IC when they opened it kaya hindi na nag-cha charge up to 14v. Everything went well since then, Para ngang lumakas pa ang hatak. But last Sunday, just barely a month after, ayaw na sya magstart. May konting redondo lang. Haven't had time yet to have an electrician look at it. Pero bakit ganun?! Defective battery ba o defective alternator? Both naman are under warranty pero bad trip lang. I just hope the shops honor the warranty with no hassle. Any ideas why this happened? TIA.
    Nov 2007
    #57
    I used motolite gold maintenance free for my pregio, and this battery will last up to 3yrs or more kung maganda ang battery compartment mo. its expensive pero no head ache naman. mas mahal pa ito sa battery ng expedition. have your alternator output and load regularly check.
Battery for Diesel Engines
