Advanced timing will cause a gain of 1-3 hp, BUT wil require you to use high octane (e.g.: expensive gas), and as with most power modifiers, will cause a slight increase in fuel consumption. Retarding will lower power and will save you some gas. But if you do lean out your carb, retarding the timing will be a good idea.
