hello question...
anong ibg sabihin pag kumakatok yng makina?...kahit mataas na yng rpm pag nag-change ng gear kumkatok parin
- what does this mean?
- ways to fix?
- how much gastos?
carburator pala ang engine....
TIA!!![]()
hello question...
- ways to fix?
- how much gastos?
TIA!!![]()
-wala sa timing
-tuneup or DIY
-mura lang. pang mcdo mo lang
alternatively,baka wala na sa lapat ang cylinder head etc. this will cost more...pakita mo na lang sa mekaniko na competent
katok or tope = engine knock = pinging or hammering = predetonation. it sounds like there's a hammer inside the engine, and that's exactly what it does. predetonation acts like a hammer on the pistons, causing major damage to pistons, connecting rod, crankshaft, cylinder head and cylinder liners.
causes: too low air/fuel ratio, too low fuel octane used, bad ignition timing.
fix: adjust carb so a/f ratio is not lean, use higher RON fuel, adjust ignition timing. cheap lang yan, cost of a tune up kung need ng adjustment ang carb or ignition timing.
but the cost of fixing damage from engine knock is high. spell "overhaul", o-v-e-r-h-a-u-l, overhaul. mura pa din? spell "new cylinder head", or how about "change engine"? wag na haba nun hehehehe...
iba connotation namin ng tatay ko pag kumakatok/kakatok makina... parang mag bogged down yung engine ang dating samin...so, in short
laki gastos
Yan din ba yung kapag cold start, malaki ang standard deviation ng fluctuation ng revs per minute pero kapag medyo mainit na nawawala na?
Originally Posted by aann
baka may tao sa loob. pagbuksan mo lang. j/k.
seriously, nasagot na nila lahat....
onga noh, bat d ko naisip yun??Originally Posted by happy_gilmore
hehehe
Thanks for the replies!
