Results 31 to 39 of 39
November 15th, 2005 09:24 AM #31Originally Posted by vinj
November 15th, 2005 12:59 PM #32
Advanced timing will cause a gain of 1-3 hp, BUT wil require you to use high octane (e.g.: expensive gas), and as with most power modifiers, will cause a slight increase in fuel consumption. Retarding will lower power and will save you some gas. But if you do lean out your carb, retarding the timing will be a good idea.
November 15th, 2005 10:25 PM #33
try using hydrogen gas instead of air to inflate your tires, it will lighten the weight of the tire. the tire center in westgate alabang (behind Total gas) does it, P50.00 per tire ata. my accord has a donut spare tire, factory supplied na coz US model.
i too play with the A/C switch pag heavy traffic and my thermostat is set at comfort cool lang.
November 16th, 2005 03:48 AM #34
iniba ko driving habit ko.. and tumaas mileage ko it was 8km/L on my 4d56 gen2 local pajero.. gulat ako im doing a lil more than 12 na ngayon yehey..
and yung lancer gsr kong matic invecs 2.. nakaka 5.5 noon.. ngayon ay naka pag more than 11km/L nagulat ako lalo na sa lancer... but irerecomputer ko uli lahat.. hahahah
- Oct 2004
- 132
November 16th, 2005 11:35 AM #35May nabasa ako sa net... un oil level din daw wag masyado puno (upper level) for fuel economy tska wag naman below the lower level - bad for engine of course.
November 16th, 2005 01:25 PM #36Originally Posted by tibo_3rd
If you live in Alabang, the Tire Center will do free refills as long as you bring your original receipt.
So far, I'm happy with the performance.
- Nov 2005
- 4
November 18th, 2005 10:15 PM #37wow! this thread is truly helpful, I almost bought the Magnetic along the Fuel Line thing! Somebody offered me that device and I almost got convinced about the idea. Taas na kasi ng GAS! The gadget is calle Super FUEL MAX! i guess it's no help in saving gas after all. might as well improve my driving habits! Thanks guyz!
November 18th, 2005 10:58 PM #38
tip ko po sa mga naka matic.. wag po tuloy tuloy apak ng gas.. pag twing nasa 2t rpm na po.. bitaw muna gas.. for.. siguro half a second lang para po mag shift sa higher gear.. para masmatipid sa gas.. i duno if it will work for everyone.. but it works realy good for me
November 19th, 2005 12:26 AM #39
asan na nga ba uli yun acetone thread? di lumilitaw when i did a searc for 'acetone'...ma PM nga si ghost hunter. sya ata yun naglalagay nun sa oto nya.
