Page 3 of 20 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 193
    usually positive muna but not coz we're following procedure but coz nakasanayan na
    ang rule lang naman huwag ma-baligtad huwag dumikit
    Oct 2011
    #22
    jumper lang yan i-parallel lang ang baterya. dami pang procedure na positive muna, negative naman sa ground dapat. etc...
    it's an 8 step process haha
    Jul 2010
    #24
    Bakit kaya SERIES ang tawag ng mga mechanic noong unang panahon pag jumper sa battery? Eh PARALLEL connection naman ito.
    Oct 2011
    #25
    bagsak cguro sa basic electricity 101.
    #26
    Quote Originally Posted by Chinoi View Post
    Sa mga matatandang mekaniko ko na nga lang narinig 'yang SERIES na 'yan.
    Noong High School years ko, natanong ko sa matandang mekaniko namin
    "Tatang, bakit po pag nagja- jumper kayo sa baterya eh sinasabi niyong I- SERIES MO NGA 'YUNG BATERYA?
    Ang tamang tawag po kasi sa ganyang koneksyon e PARALLEL."
    Sinagot niya naman ako ng tanong rin:
    "O e di ba pag ikakabit, sa ingles eh SERIES?"
    Sa tanong pa lang niya, nakuha ko na ang sagot sa tanong ko. Napa- ngiti na lang ako...
    May 2013
    #27
    Strictly speaking, it is a series connection because only a single load(car to be jumped) is connected to the single source(battery). Electron flow during jump start only occurs in a single loop. Yes, the batteries will be connected in parallel(source to source) but the car would be in series with the battery(or batteries in parallel).
    Sent from my HTC One X+ using Tapatalk 2
    Oct 2011
    #28
    ah okay. un pala ang explanation kung bakit series.
    #29
    ^ Wrong
    If you series the batteries it will produce 24 volts.
    #30
    Reason behind positive first is for safety.
    Bridging negative first could pose great chances of positive accidentally touching the negative since the surroundings(car chassis) is already electrically negative.
    Same safety practice for -48VDC Datacom/Telecom setup, but it uses negative as the "hot" wire (chassis being positive).
Jumper cable amp rating
