Results 121 to 130 of 193
July 15th, 2013 12:15 PM #122
nahilo na ako sa thread. yun negative ba dapat i ground pa or hinde...? o flashlight na usapan?
July 15th, 2013 12:28 PM #123
sariling gawa na jumper cable
pang start ng 24V trucks and heavy machines
di ko na kailangan problemahin ang amp rating amp rating na yan
that's welding cable
more than enough for any starter we got hereLast edited by uls; July 15th, 2013 at 12:31 PM.
July 15th, 2013 12:34 PM #124
i have a black and decker jumpstarter kit (since A/T oto ko). instruction
nya is + to + (Jumpstarter kit to car batt)
then - to car chassis/solid body part.
reverse pag tapos na.
Boost Ampere: 375 instantaneous cranking amps (according to the manual).
July 15th, 2013 12:39 PM #125
Parang gets ko na kung bakit not recommended ang negative to negative terminal. May napanood ako sa Discovery Turbo (The Garage). Pekeng M3 ginagawa nila and namatayan ng battery sa shop kaya ni-charge muna. After a few minutes charging nagstart na so tinanggal na ng mekaniko ang clips ng charger. Biglang BOOM! Yun pala di nya na-unplug muna ang charger bago tinanggal ang clamps. Nagspark pagtanggal and nag-ignite ang gases sa loob ng batt. Takbo agad sa CR ang mekaniko para maligo.
So if nasa block or body ang ground connection mo pagtanggal less chances mag-ignite dahil malayo sa battery. Once natanggal na yun wala nang circuit so safe na tanggalin ang iba.
July 15th, 2013 01:00 PM #126
ganto na lang, kung ayaw neg to neg, edi lagay sa body neg.
edit: sa jumper cables, Ewan ko ba kung bakit kailangan alalahanin amp rating, basta gumagana ok na yan. kahit kasing kapal pa ng braso, 12v to 12v or 24v to 24v, yan pa rin ang dadaloy na voltage.Last edited by [archie]; July 15th, 2013 at 01:06 PM.
July 15th, 2013 01:01 PM #127
when you're charging a battery using a charger the battery gets warm and the battery acid will bubble and you'll smell acid vapor
but that doesnt happen immediately after you connect the charger. it takes several minutes before that happens
connecting a good battery to a dead battery is like connecting a battery charger to the dead battery. it's not gonna make the dead battery charge up agad and release vapor
so it's unlikely a spark will cause the dead battery to explode
overly cautious lang ang mga Kano kasi ayaw nila mademanda
July 15th, 2013 01:11 PM #128
wala naman pumipilit sa inyo mag neg terminal to neg terminal
use body ground all you want
like cathy did. she followed step by step instructions pero di niya na-start car niya. may nagsabi tuloy stuck-up na makina niya
pero napaandar niya noong pinalitan niya ng battery
so what went wrong?
suspetcha ko body ground. mali location pagkalagay ng cathy. kung nilagay niya sa neg terminal umandar sana yan
in those few seconds kukulo ba ang battery acid at magrelease ng vapor? i doubt it
- Nov 2009
- 3,484
July 15th, 2013 01:36 PM #129Anlake! Yung DIY ko from inverter welder kaya gauge 3 lang, pero palagay ko kaya din magstart ng 24V neto. Pwede din double purpose, tow cable..haha
Dapat well ventilated. Hydrogen buildup nangyari.
Dapat consider wire gauge, ang analogy ng wire is parang tubo ng tubig. The larger, the more current could pass. Kung malaki ang amp draw ng starter at solenoid, iinit lang ang wire (electron congestion).
As a general rule based fron nabasa ko - gauge 6 for small cars, extending the length increases the resistance so u have to increase the gauge, the bigger/shorter the better.Last edited by 12vdc; July 15th, 2013 at 01:40 PM.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
