Page 6 of 38 FirstFirst ... 234567891016 ... LastLast
Results 101 to 120 of 754
    Jul 2006
    #101
    working red positive to dead red positive
    working black positive to deal black positive
    May naalala kasi ako na may proper seqeunce e nalimutan ko na. Pati sa pag tanggal ng clamp may proper sequence daw
    Tapos una ko sisindihan yung working car diba?
    Working red positive to dead red positive
    Working black negative to the engine block of the car being started ( anywhere that there is solid metal where the alligator clamp can be attached)
    Your main goal is to jump start the car, by doing the above you are effectively using the battery of your altis to start your corolla via the jumper cables. If you connect the poles, you are decreasing starting current from your good battery because your dead battery is in part absorbing it.
    Mar 2013
    #102
    I like LSB's conservative approach...
    Wala ka namang planong tangalin ang battery mo habang umaandar ang kotse para malaman kung ok pa alternator mo, hence my post.
    Okay lang matagal ko na talaga balak bumili ng Jumper cable. Yung battery monitor okay lang kasi kinakabahan na rin ako sa battery ng Altis ko kasi 3 yrs old na gumagana pa.
    3yr old battery... Dagdag mo na lang yang pambili mo ng battery monitor sa bagong battery, wag mong hintaying mamatay yang battery ng altis palitan mo na yan.
    Jumper cable is a must, so bilhin mo yan.
    #103
    Quote Originally Posted by ClaNker View Post
    Ugali ko talaga intayin hanggang maubos yung battery, tawag motolite kung sa bahay abutan. Pag sa labas, tulak Pero this time nga ayokong intayin kasi iniisip ko bumili ng Amaron eh wala naman ata sila delivery. Pwede rin sa Casa ako bumili ng battery, ang galing kasi ng stock battery nila umabot ng 3 yrs. Yung motolite kasi right after warranty(18 months) namamatay na
    o diba? may ganyan ganyan pa kaya pumalpak ka sa ginawa mo dati
    pula sa pula
    itim sa itim
    start!
    that's it
    Mar 2013
    #105
    3yr old na yang battery mo palitan mo na yan the soonest possible time. Bili ka ng jumper lagay mo sa trunk for emergency purposes, wag battery monitor sayang lang pera mo.
    #106
    Baka kasi umabot pa ng 4 years
    Mar 2013
    #107
    Hoy Cathy di ka ilocana no. Palitan mo na yan.
    #108
    Ilocana ako sa ibang mga bagay. ha ha ha! Baka pwede pang isagad e
    Feb 2013
    #109
    Ano ang pwede pang isagad? Kung mahilig ka sa sagaran magkakasundo tayo.
    #110
    Ayan na, nagsalita na ang master ng jumper cables....
    Tumpak....
    Also, if I may add, safety reason din para maiwasan ang fumes coming from the battery kung direct terminal to terminal connection.....
    Pagtanggal,- reverse lang ng procedure...
    19.4K:tomato:
    Feb 2009
    #111
    [ame=http://www.youtube.com/watch?v=li1PL6EpFF8]Saab Automotive 101: How to Jump-Start Your Car - YouTube[/ame]
    Jun 2011
    #112
    Maam c4u when using jumper cable... stay mo muna ng 5-10mins... before starting.. para magka charge din ng kunti yung dead battery mo...
    then start....
    #113
    Tumpak....
    19.4K:tomato:
    I literally LOLd on this :rofl:
    Oct 2011
    #114
    Is it advisable to jumpstart a car with the jumper cable on the good battery (negative terminal) connected to the ground of the other car instead of connecting it to the negative terminal of the dead battery directly?
    Feb 2009
    #115
    if you really think about it, you try to reduce the risk of a spark around a weak battery that has potential of gassing (hydrogen gas leaving the vents of the battery). the result is a battery sized hydrogen bomb. i personally connect the negative clamp of the dead car on the engine block before making the last connection to the negative terminal of the good car's battery (less than likely emitting hydrogen gas). some cars, the battery is in the trunk (bmw) some are inside the passenger compartment (cadillac allante, chevrolet corvette) and the jumper terminals are in the engine compartment. this makes the likelihood of the cable spark away from the battery. in military vehicles, the jumper system (called slave cables) are installed on the side or the front of the equipment that has idiot proof connections so even in pitch darkness (tactical conditions) you don't misconnect the cables
    #116
    i just connect the jumper cables to both batteries. we have done it often enough for decades now..i think the flow of air from the fan prevents hydrogen from accumulating.. we also do not rev the engine hard.. para lang nag-start nang ordinary.. start and idle, or maybe a little pedalwork for a few seconds.. then straight to the battery store for replacement.
    Feb 2009
    #117
    it is not a myth that hydrogen gas comes out of the battery vents if you are charging a battery. similar to charging, jump starting a vehicle, the weak battery produces hydrogen gas. there is always that risk. that is why the battery top warns you not to smoke, have an open flame and avoid sparks when connecting or disconnecting a battery. i once had a co worker in a construction company who was charging about thirty 7D batteries for heavy equipment who was a smoker. he would check batteries charging with a lit cigarette between his fingers. i told him about the risk. and he would brag that he had been doing this for decades. one lucky day, two batteries being charged exploded because of his lit up cigarette. he was lucky enough only two batteries exploded. he came running out of the shop screaming in pain from the cuts he sustained from the battery casings and the acid on his face. accidents are avoidable specially if you the risks. experience has it, batteries do explode when they are gassing and there is a source of ignition or spark. that co worker has since passed away, rest his soul but the lesson i learned from his indifferent mistake lives on
    http://www.google.com/search?hl=en&s...mg.rITlQ07mfzs
    Jun 2011
    #118
    battery explosion injuries - Google Search
    sir tanong lang po..
    it means ba kahit alternator charging lang can cause this?
    hindi po ba constantly nag charge ang battery natin when the car is running?
    paano nalang po yung ibang sasakyan na nasa loob ng sasakyan ang battery?
    it's one thing to be careful and it's another thing to be OA
    sa sobra dami mo iniisip that can go wrong halos hindi ka na kikilos
    para safe ka pwede ka mag suot ng hazmat suit... just to jumper-cable a tiny 1sm battery to another tiny 1sm battery
    Mar 2013
    #120
    Ano na ang nangyari, nasa theory ng jumper cable parin ba?
How to Know If It Is Only A Battery Problem
