Originally Posted by
lowslowbenz
Working red positive to dead red positive
Working black negative to the engine block of the car being started ( anywhere that there is solid metal where the alligator clamp can be attached)
Your main goal is to jump start the car, by doing the above you are effectively using the battery of your altis to start your corolla via the jumper cables. If you connect the poles, you are decreasing starting current from your good battery because your dead battery is in part absorbing it.
