Results 11 to 20 of 55
Does a voltmeter (using the cigarette lighter plug) help us determine the health of the car battery?
March 11th, 2019 07:09 PM #11
Not really useless. I have one installed on my car. One morning it read 11.8 volts. And true enough, may hesitation sa pag start.
Was supposed to go straight to a motolite dealer to buy a battery, dunno why i stupidly detoured to fillup with gas. Ayun ayaw na magstart after ko magpa karga. Good thing the gas station had a battery booster device of some sort.
March 11th, 2019 07:25 PM #12
I agree with the volt meter, it's actually what the battery shops use to test starting current.
Di ko kaya bumili Ng 100k na analyzer bro, what I got was the same unit as OJs, nagloloko lang to the point na dinala ko pa sa casa kahit bago Ang battery to have the electrical system checked which they would gladly accommodate for 1.5k plus pumila ka at mag antay ng 1 whole day. So I did the next best thing, brought it to an electrical shop and a battery shop, both found nothing wrong.
Fast forward 7 months later, battery is fine. [emoji3]
Sent from my Mi A1 using Tapatalk
- Feb 2014
- 2,711
March 11th, 2019 08:05 PM #13
mura lang batt analyzer. it's not rocket science. i'm still wondering how Midtronics can get away w/ selling their super expensive analyzers
what if i told you that my smartphone-connected analyzer costs less than a jump starter "powerbank" gadget (but costs more than jump cables). but i do get your point. not all people are geeks (so i do have multiple jump powerbanks, multiple jumper cables, and an analyzer)
- May 2017
- 2,128
March 11th, 2019 08:35 PM #14Digital Voltmeter (testing the car battery itself) = mura lang ito mga less than 500pesos sa Robinsons Handyman
= can test the state of charge of battery (ideal is 12.6 volts and above)
= this is the most important, can see the cranking volts when starting the car, like for example showing a below 8.5volts mean malapit na palitan ang battery
= can also test the alternator if it is charging the battery (should be showing 13.6 volts and above) (below 12.6volts means there might be something wrong with the alternator) (over 15 volts means the alternator is overcharging the battery and the regulator needs to be fixed)
Cigarette Voltmeter = can see the state of charge
= can see the alternator charging
= But does not show the cranking volts
= mga 990 pesos nakita ko sa Concorde
Battery Analyzer = mga 5,900 pesos meron sa Blade Autoshop. Mas makakamura ka pa sa Lazada mga 2,500 lang siguro makakakita ka na doon.
= can see the number of functioning Amperes (CCA)
= can show the State of Charge, SoHealth
= shows a more accurate cranking volts for the Cranking Amps
= shows the Internal Resistance
= can perform a ripple test if there is too much A/C current that can destroy the electrical system.
You are better off buying the battery analyzer or digital voltmeter than the cigarette voltmeter
- May 2017
- 2,128
March 11th, 2019 08:46 PM #15
March 11th, 2019 09:07 PM #16
The lower the better. I don't know the magic number but as the battery ages, the internal resistance goes up. I suggest that you just get a battery analyzer to remove the guesswork.
https://www.lazada.com.ph/products/n...QGzD5&search=1
- May 2017
- 2,128
March 11th, 2019 09:54 PM #17nabasa ko lang sa internet "High resistance causes the battery to heat up and the voltage to drop under load, triggering an early shutdown"
- May 2017
- 2,128
- Nov 2009
- 3,509
March 11th, 2019 11:46 PM #19Health of battery: no
Health of alternator: yes
There are 12.5V terminal voltage battery that won't crank the starter simply because it has the Voltage but not enough juice/Current.
March 12th, 2019 10:17 AM #20
True.
The reason being, when there's a demand for current, a high internal resistance battery will cause its voltage to drop well below what is necessary to start the vehicle. This is even though the battery may still have enough capacity. Once the internal resistance gets to a certain point, you can only relegate it to run low current accessories.
That's why some old batteries can still be re-purposed for use to power emergency lights.Last edited by oj88; March 12th, 2019 at 10:19 AM.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
