Results 41 to 50 of 55
Does a voltmeter (using the cigarette lighter plug) help us determine the health of the car battery?
March 15th, 2019 11:07 AM #41
March 15th, 2019 11:38 AM #42
March 15th, 2019 12:26 PM #43
- 52,731
March 15th, 2019 01:14 PM #44hindi naman namamatay ang cig socket when starting. at least, not in my car.
but the electricity flowing to it can get pretty low, depending on how strong the battery is, how many other accessories are in play, and how thick the wiring and grounds are...
if one plugs an incandescent bulb accessory into it and then start the engine, the bulb dims but not completely extinguishes. some auto mechanics even have a regular but specially-chosen bulb, for precisely this! "doc, pag hindi na umilaw yung filament ng bumbilya, ibig sabihin mas mababa na sa X volts ang nariyan."
a digital gadget that requires constant voltage, may shut down when the voltage powering it gets too low.. but an old electromechanical meter will just move its needle to the low reading, which is how it reads low voltage, which is what we wanted to measure in the first place.Last edited by dr. d; March 15th, 2019 at 01:35 PM.
- Mar 2010
- 2,257
March 15th, 2019 01:49 PM #45If OBD can get data while cranking it means the port is still powered.
It reminds me in the 80's when we used the digital storage scope to capture and record the pulses of an equipment in order for us to adjust it later to the correct peak to peak voltage required.
- May 2018
- 611
March 15th, 2019 02:00 PM #46Teka, question na rin.
Perhaps using an old fashioned battery hygrometer will give a better indication of battery health? Medyo tedious nga lang, kasi you'll have to draw battery acid into the tube for every cell.
I'm not sure if applicable nga lang ito sa sealed type na maintenance free... but I think some maintenance free batteries have covers designed to be pried off with a flathead screwdriver.
March 15th, 2019 02:38 PM #47
March 15th, 2019 02:48 PM #48
We have the same vehicle, except for the transmission.
This is how my D4D Innova behaves when turning the key from OFF/LOCK > ACC > ON > START > ON
While the engine is cranking (ignition key on START), the ACC line experiences a power cut-off. My Echo Dot, and even the HU goes blank and reboots.
If you notice, the backup sensor switch indicator LED and the climate control didn't even 'blink' when the starter was engaged. This indicates that they are wired with the ignition "ON" position and is not affected by the ACC line cut-off.
- 52,731
March 16th, 2019 11:07 AM #49i have two VOMs, here at home. one digital-display, one analog-display.
but tinatamad akong mag-dissect ng cig lighter plug, just to be able to connect 'em.
and i'm a bit uncomfortable, sticking them probes inside the cigarette lighter socket, while i use my third hand to twist the key...Last edited by dr. d; March 16th, 2019 at 12:23 PM.
March 16th, 2019 11:18 PM #50
Allow me.
That's fairly conclusive. Power is temporarily removed from the ACC line whenever you crank the engine. So a dashboard voltmeter that's tapped to the cig socket is useless to measure the battery voltage while cranking.
Note: My analog meter is 'zeroed' for when it is lying down on my bench. Hence, the needle isn't aligned to zero (0) with no input while propped up in this test.Last edited by oj88; March 16th, 2019 at 11:28 PM.
