Results 1,671 to 1,680 of 2247
- Oct 2009
- 2,271
June 6th, 2019 04:02 PM #1671pina check ko sir kailangan daw linisin lang ung tumatagas sa ibabaw ng takip.ganun daw talaga un.kasi naka tapal lang ung takip at hindi katulad ng iba na di ikot.kaya posible daw tumagas.sa gamit naman po okey naman..siya walang pag babago un nga lang masyadong maarte at kailangan palagi mag check kung hindi kalawang aabutin ng mga katabing metal..
dec 2018 ko lang nabili may monitor po ako volt meter sa sasakyan 14 volts lang po
hindi pala maintenacefree ito kasi palagi kang mag lilinis ng batterya..Last edited by jaypee10; June 6th, 2019 at 04:17 PM.
June 6th, 2019 06:36 PM #1672
yun mga de ikot bro may release hole sila.
pag grabe problem ng battery mo parang dumudura.
hanggang ngayon di ako nagpost ng engine wash diy ko kasi di ko pa naayos yun mga namuting part dahil sa dura ng motolite battery [emoji1787]
- Oct 2009
- 2,271
- Jan 2008
- 4,726
June 6th, 2019 08:30 PM #1674Tip: kung may white formation sa battery post.. just use hot water to wash it away..
June 7th, 2019 05:19 AM #1675
- Feb 2014
- 2,563
June 7th, 2019 01:47 PM #1676my motolite is like that, when old it weeps acid, which corrodes the hold-down bracket. also creeps down to the metal tray that the batter is sitting on which gets corroded as well
i had to recoat the bracket w/ epoxy primer to restore it to factory condition
- Dec 2007
- 186
June 7th, 2019 02:27 PM #1677i have always wanted to try the Amaron but the location of the dealer in my place is quite far. if any problems developed, it would be another hassle for me.
what i discovered is the green motolite battery i am using would always fail a month before the warranty expiry date. ilang beses na nangyari to so for a price of one battery + the free warranty battery,
more or less almost 4 years ang gamit on a daily driven car. not bad
- Oct 2009
- 2,271
June 8th, 2019 04:51 PM #1678
June 8th, 2019 08:57 PM #1679
i know, pero may butas sya sa gilid. sa amaron kasi kahit papano palapas yun labasan. sa motolite maliit na bilog. napinturahan ko na yun part na natamaan pero grabe yun nangyari sakin, di lang leak talagang dumudura inabot engine cover halos.
June 9th, 2019 01:32 PM #1680
eto yun natalsikan ng motolite battery leak
Good thing you don't have an oil pressure gauge. It'll make you think twice about going 50.
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
