Results 1 to 20 of 2297
Threaded View
    Oct 2009
    that's abnormal. that's acid. it can ruin paint and dissolve metal.
    if under warranty, bring it to your warranter, po.
    otherwise, wash it down with lotsa water. then observe. open it if you can, to remove some of the liquid inside the cells.
    if repeating, have your charging system checked. you might be over-charging, causing the liquid to bubble out.
    pina check ko sir kailangan daw linisin lang ung tumatagas sa ibabaw ng takip.ganun daw talaga un.kasi naka tapal lang ung takip at hindi katulad ng iba na di ikot.kaya posible daw tumagas.sa gamit naman po okey naman..siya walang pag babago un nga lang masyadong maarte at kailangan palagi mag check kung hindi kalawang aabutin ng mga katabing metal..
    dec 2018 ko lang nabili may monitor po ako volt meter sa sasakyan 14 volts lang po
    hindi pala maintenacefree ito kasi palagi kang mag lilinis ng batterya..
Amaron battery
