ask ko lang kung nalalagyan ng distilled water ang amaron battery, hindi ko makita yung butas na pwedeng pag lagyan ng distilled water
i do not know how your battery looks like.
but from what i observe in mine, the filler holes are there, covered by a paper or plastic sticker. para pag binuksan mo, ay obvious na obvious, "for warranty purposes".
i googled it. it seems, yours are covered by a plastic panel that can be removed. google it, sir.
My Amaron battery powered car had been relegated to coding duties for a while now. I thought baka mapundi na yung baterya due to the intermittent usage, pero so far malakas pa naman. More than 4 years (2012???) na siya if I remember right.
Dead na 1SN Amaron nang Gen1 CR-V ko. Feb 8 2016 binili. Can't retain a change anymore. Disappointed ako 21 months lang ang buhay.
Switching to Panasonic now.
sometimes, the cause of not retaining charge, is the charging system's in-ability to provide that charge.
bring your vehicle to their outlet, po. they will probably check your charging system. if it proves to be the culprit, you probably won't get a replacement battery.
I think you're the 3rd or 4th tsikoteer after me who has a dead amaron right after warranty. Switched back to motolite, which would die within warranty naman[emoji51]but really wanted to try out panasonic pero motolite lang meron sa malapit na store
Have to check my other amaron sa ibang car
Isa ako sa may ayaw na sa amaron. It never failed na mag leak sa amin. 4 batteries out of 4 nag leak. Panasonic blue battery na pinalit ko sa innova namin
Hmmm, so lots of bad reviews pala with Amaron. I thought of changing to Amaron once my stock battery dies. Might stick with Motolite then.
