Page 7 of 8 FirstFirst ... 345678 LastLast
Results 121 to 140 of 148
    Nov 2018
    #121
    Pa-bump up lang. Car is a Isuzu Big Horn. Had no problems in starting and driving; however, once the aircon is turned on, all indicator lights start blinking and stop once the aircon is turned off.
    Read good reviews about Rey's Electrical so decided to go there. After checking with a voltmeter, they said the alternator needed to be replaced. So had it done but the problem still remained. Sabi nung isa na gumawa dun something about crankshaft pulley na di na nila kaya and that I should see a mechanic.
    Possible kaya na di naman dapat ireplace yung alternator? Was disappointed with the result coz I had relatively high expectations na madi-diagnose nila ng tama at masosolve nila yung problem. Am not that knowledgeable yet (still learning) and I kinda expected them to know better.
    Any suggestions kung anong klaseng shop ba dapat ko dalhin? Thanks for all the helpful tips.
    Dec 2017
    #122
    Quote Originally Posted by Wachia View Post
    Most probably, it's the crankshaft pulley. The same thing happened to me on our hilander.
    The bearing is broken and that is why it couldn't take the additional load of the A/C. You get all the indicator lights because it couldn't turn the alternator at the correct RPM as it couldn't carry the A/C load and power steering pump.
    Since they were not able to resolve the issue, I suggest that you ask them to return the original alternator together with your money.
    To answer your question, I can't remember the name of the shop where I brought our hilander. It's somewhere in Bulacan...
    #123
    Crank pulley, aka harmonic damper, does fail. The rubber core breaks from the metal pulley. When this happens, everything that main pulley drives will be affected....A/C, charging, in some...the cooling, steering, supercharger, etc. The fix is simple....replace the pulley. To do that, you'll need a crowfoot pulley puller. I've invested in 1 that has gone lent around I don't even recall who the last one was.
    Here's a basic how-to:
    How to Remove a Crankshaft Pulley in Your Car - YouTube
    May 2011
    #124
    Be very careful of honda civic and accord engines, the crankshaft turn CCW. It will tighten the bolt more until it snaps with this procedure. Do not believe all of this man's videos. Honda civic is west-east orientation (engine on the left or driver side and the transmission/transaxle on the right or pax side).
    #125
    Quote Originally Posted by mina_nuka View Post
    As you warned, Scotty did advise to see how the engine turns. Never do this trick w/o checking.
    Jan 2008
    #126
    Ang engot naman ng shop na yan.... siguro kasi electrical lang alam.. automatic palit agad alternator.. kung tiningnan maige yan.. makita nya na mabagal umikot yung belt.. baka nga humihinto pa yan pag ON ng compressor
    #127
    ito dahilan kung bakit sa exalta nalang ako derecho pag may problema. lahat halos andun, si suking mechanic ko sana na magaling mag diagnose nasa toyota new jersey na LOL
    Nov 2018
    #128
    Thanks for the reply. Repair ba ito or may papalitan? Do you remember approximately how much it cost? Saka is it something an ordinary auto repair shop can do o specialized one?
    Nov 2018
    #129
    Thanks for the advice. Will have a look see
    Nov 2018
    #130
    Kaya kakainis kasi they took the easy way (recommend palit agad), instead of looking carefully and diagnosing the problem correctly.
    What's worse is that during the replacement, they somehow damaged one of the hoses for the brakes and I lost my brakes as I was leaving. Pinalitan naman yung hose pero it was still a scary experience as I almost hit another car.
    Dec 2017
    #131
    As mentioned / implied by *travajante, you need to replace it. It won't cost you that much.
    Aug 2019
    #132
    Sir question po kase yung Nissan X Trail ko T31 wala ako napapansin na different until yesterday, may parang tunog na somewhat lata na may bato or something tapos when I checked yung loob, I saw na yung alternator area may maingay don parang kumakalansing na metal tapos yung rubber is moving but there’s a part at the bottom where the other side of the rubber is connected) na parang nagsshake. Sabi daw po more on either loose or too tight siya or bad wiring na daw. Any advice on this one?
    #133
    Quote Originally Posted by bernardomkr View Post
    i tried, but i can not make heads nor tails of your narration.
    does your engine still start?
    does the battery icon remain lighted up, after the engine starts? that means, your alternator isn't alternating.
    my recommendation is, bring it to the alternator shop asap, before your battery gets too weak to power your engine. when that happens, you're stranded.
    #134
    Nuline Overrunning Alternator Pulley OAP Engine Bay OAP012 fits X-trail 2.0 T31
    Nuline Overrunning Alternator Pulley OAP Engine Bay OAP12 fits X-trail 2. T31 | Trade Me
    May 2007
    #135
    sir wachia, Rey's Electrical Cubao ba ito?
    Sep 2019
    #136
    mga boss newby lang patulong naman po naputulan ako ng alternator belt pede ko pa b maitakbo yung kotse papunta ng talyer para mapagawa ok lng kya yun ,baka kc tumirik sa kalsada e thanks po...... mitsubishi lancer 2003 cvt MX po kotse
    Dec 2017
    #137
    Quote Originally Posted by deckssantos View Post
    Yes and no. Yes, you can start and run the car. No, because you won't​ be able to reach your destination.
    Jan 2008
    #138
    Depende sa layo... mag overheat yan at maubos ang charge.. titirik ka lang
    Sep 2019
    #139
    salamat mga boss .. delikado pala ubligado pala papuntahin ko mekaniko sa bahay para dun palitan ng belt.......
    #140
    i do not remember, what else that belt powers.
    the alternator... the power steering?..
    if just the alternator, you can drive it for as long as there is enough power in the battery to fire up your engine and your aux fan. if your trip is malapit naman, you may just complete it before something really bad, happens.
    that is, assuming you can start the engine. the more times you start it, the shorter the above distance will be.
    but if your belt also powers the power steering (which i believe it does), i would not recommend driving that car on the street. it is very very difficult to move that manibela without the PS steering.
Alternator Repair
