Results 41 to 50 of 148
March 27th, 2008 04:38 PM #41
I BEG TO DISAGREE with You COBALT BLUE
, if you dont have personal experience about pregio or any korean cars its a big big mistake to comment
i bought mine 1998 brand new in commonwealth auto center. in the 10yrs of my pregio maniwala ka sa hindi wala pang major repair, radiator, alt, tranny all are stock. no overheating kahit ibabad mo sa traffic. i travel baguio, pagupod, cagayan for many times hindi ako pinahiya. sabi nga ng wife ko ang dami nagsasabi ng negative sa pregio but in reality its very nice and comfy and easy to maintain kasi old tech ang engine but decent power.
Now the odo is 135K and still working very fine and smooth. How come its dangerous.... Siguro mas dangerous yung tao na nakainom at wala sa sarili habang nagda-drive
malamig ang a/c ng pregio basta well maintain and no freon leak. hindi mo ba alam in northern province like la union, pangasinan maraming bumibyahe na naka pregio paakyat ng baguio... before i bought my pregio, my family owned a honda civic but binenta namin dahil gas guzzler, masikip, mahal ang parts. mas madali magmaintain ng diesel engine compare sa gas....
baka yung nabili ng company nyo eh lemon van o hindi marunong ang driver....
peace men
- Jan 2008
- 4,726
March 27th, 2008 11:48 PM #42to kia van owners out there having problems with your alternators.. you may check my post at the kia cars talk in the kia carnival/sedona thread... if your alternator widings are not yet busted or toasted.. most likely you have a problem in the charging pole and wiring to the battery...on you have a LOOSE SOLDERING ON THE DIODES ASSEMBLY!! just make sure that the electrician will re-solder all points no matter how good they look... i had the same problem with 2 kia vehicles i owned.. first is a besta van, when we had alternator problems we immediately replaced with reconditioned surplus but after two years we had the same charging problem.. but this time we didn't replace the alternator but i performed a through check until i discovered LOOSE solder on the diodes causing poor charging.. after re-soldering problem was solved....
when i bought a kia carnival, i also experienced the same poor charging problem, i did the same thing by re-soldering the diodes points.. problem solved!! i have excellent charging!!
also make your charging poles reinforced and make sure no loose connections fromt he alternator to the battery..
- Nov 2005
- 311
April 29th, 2009 05:33 PM #43just reviving this thread. I think my alternator is broken. 95 corolla big body po ang car.
baka may nagpapalit or nagpa repair ng alternator sa inyo lately. paki post naman po ang price, a year ago pa kasi tong thread. magkano kaya new or surplus alternator? or typical price ng repair?
any good shops in muntinlupa/san pedro area? thanks po!
April 29th, 2009 06:33 PM #44
yesterday nagpaayos ako ng alternator for 96 civic.
ang sira putol ang wiring sa rotor. not charging nakailaw ang batt indictor sa dashboard.
pinagawa sa REC sa bacoor cavite.
pinalitan ng bearing at pinalitan ng rotor na bagong rewind(recondition) para mabilis na iniwan na lang ang luma at yun naman ang gagawin nila para stock nila. cost 1500pesos, 1200pesos for the repaired rotor plus 150pesos X2 for the bearing.
- Nov 2005
- 311
April 29th, 2009 06:49 PM #45thanks for the reply. may idea na ko ng price.
since the battery is now dead, im planning to jumpstart (using other car) para madala sa shop, ok lang naman yun no?
guys, baka naman meron may alam ng trusted shop sa muntinlupa/san pedro area.
July 28th, 2009 03:20 AM #46
The other day I ran into a little flood. Maybe more than half ng wheel ng Xtrail. When I started the engine nung morning I heard a screeching sound. Ignore ko lang coz I thought nabasa. On the way home, the all the warning lights went on until maubos na yung charge ng battery. Pina tow ko na lang.
Now I switched batteries, nag start naman pero naka ilaw yung Battery icon. Wala naman screeching sound pero mukhang sira na yung altnernator. Pwede pa ba ma-repair yung alternator?
July 29th, 2009 08:30 AM #47
- Feb 2008
- 38
August 9th, 2009 09:00 AM #48got a 110amp alternator (surplus) for my nissan serena for P3500. Twice ng nasira alternator ko.
am planning to put an ampere gauge or voltmeter sa panel para malaman ko kung sira na uli alternator ko.
as per sa electrical shop na pinuntahan ko, sakit ng some nissan cars and korean models ang alternators. seldom sa toyota and nissan models. mas bihira sa mga high end european cars....
August 9th, 2009 09:30 AM #49
Sometimes, a good cleaning can bring alternators back to life.
Some SM ACE hardwares alrdeay sell alternators off the shelf
August 10th, 2009 04:34 AM #50
Ayaw bumukas nung windows nung sasakyan ko then sumunod namamatay na yung headlight ko. do you think guys my alternator is the reason for this? newbie here.
At the 60-80 range the Seal's ICE would be taking over the propulsion duties from the electric...
(11th Gen) Honda Civic
