Page 120 of 221 FirstFirst ... 2070110116117118119120121122123124130170220 ... LastLast
Results 2,381 to 2,400 of 4415
    Dec 2012
    #2381
    Tropapits. Went to Goldcars today and installed the ff:
    HU with back-up camera (no headset monitors)
    HID kits (low beam and front fogger)
    Chrome for headlight and backlight
    Rainvisor
    (spent 54K for everything).
    Just arrived at home (Quezon - Pasay - Gen Trias Cavite) and observed the ff:
    1., HID (low beam) is not working (dead, then flashing both, then flashing 1 by 1). I just used it for ~1 hr (Pasay to Cavite). I'm very frustrated kase, madilim sa gabi (esp when the low beam is flashing 1 by 1). Goldcars installed H1 (8K).
    2. I observed the OEM HU that the screen brightness changing from time to time (normal then too bright, then back to normal, then bright...just seemed nag-auto dimlight something). I'm just using FM radio from Pasay to Cavite (no touching).
    3. HID front defogger - no problem - ok.
    Has anyone observed #1 and #2? Definitely, i have to go back again to Goldcars for the HID low beam.
    Sir numbah, thanks for the calls/text today.
    #2382
    You're better off with high output bulbs anyway unless you're willing to do a retrofit/projectors.
    I'd think na mas maganda light output/cutoff/buga ng Philips Xtreme Vision / Osram nightbreaker than a set of HID (non-retrofit) PnP HID kit.
    Easier to maintain too.
    Oct 2011
    #2383
    Quote Originally Posted by delta00 View Post
    Rainvisor
    Sir where ka sa GenTri? Everyday drive ako diyan di ko pa na-sight TB mo. Meron akong nakita TB sa Gateway Business Park hehe.
    Dec 2012
    #2384
    Quote Originally Posted by Lapella View Post
    Gov hills sir. Yes sa gateway ako nag wowork.
    Dec 2012
    #2385
    Quote Originally Posted by mda View Post
    Thanks sir. Not familiar with any HID kits and just asked dealers/Goldcars. Sana we should have some HID 101 lesssons para ma-educate folks. Time (na pakabit/repair) is more critical than cost..hirap kase mag travel to Banawe from Cavite
    do you recommend something as a replacement? The warranty from goldcars is 1 year...
    Jul 2006
    #2386
    Rainvisor
    There must be some problems with the ballasts or maybe the wirings are a bit loose kaya on/off ang HID mo. We're better off with HIDs than those high output halogen bulbs since we have projector lamps. Better to bring your HIDs back to Goldcars and have them check the ballasts and the wirings. Retrofitting our projector lamps to original HID projector lamps will give us the best output (brightest and widest output), yun nga lang it is expensive, around 19-24k kay sir garyq. Pero nonetheless, mahal nga siya pero sulit naman. For now, sa simula PnP HID kits muna tayo then pag may budget na ulit, pwede na retrofit.
    Regarding the HU, check its settings. Baka naka auto brightness nga yung screen. I didn't experienced it nung tinest ko yung HU.
    Jan 2013
    #2387
    Ltz ata yun kay delta kaya projector... di ito retrofit sir. At high output baka maglagay pa ng additional wiring and relay allergic ang mga SA dito
    Jul 2006
    #2388
    Quote Originally Posted by zephyro90 View Post
    Yup I know LTZ yung kay delta00. What I mean by retrofit is changing the projector lamps. Kaya ko nasabi ito since our projector lamps are for halogen lamps, not for true HIDs. Yun nga lang, very complicated since may manual leveling feature ang headlamps natin, mawawala yun pag nagparetrofit tayo.
    BTW, I confirmed thru SMS with Chevy Philippines' AVP for Service and Aftersales that the dexos2 fully synthetic oil is already available in all Chevy dealers since last week. He even issued a circular regarding it. So *delta00 and *safala, looks like your service advisors tricked the 2 of you into using mineral oil, para every 5k kms kayo babalik sa kanila.
    Jun 2009
    #2389
    Monday Morning sighting.
    On my way to my work place nakita ko uli along UN ave. Auburn Brown LT( Quezon Blvd dealershi), I can't hold back & stopping to have a second, third glance.
    Almost 3months na ang TrailB ko but still have 2.3 K km sa odo, come saturday will bring it to laguna via teresa, tanay route.yesterday nag top up ako(petron) D.O. courtesy of my daughter's fuel subsidy he he he .
    Jul 2012
    #2390
    Hey Guys saw for AD for TrailB re-badged by Holden.
    [ame=http://www.youtube.com/watch?v=pQVJ0x9cUCw]All-new Colorado 7 - on sale now - YouTube[/ame]
    Dec 2012
    #2391
    I'm planning to retrofit for quad xenon but there will be slicing made so... nagdadalawang isip ako... mura na retrofit nya ngayon compared before.
    Dec 2012
    #2392
    Just spoke to my agent... according to him 2nd week to last week of feb daw ang mga trailB colorado daw ang mga dumating mga pending pa daw dati yun(ang dami colorado sa mga showroom nila)... as an importer I find this shady. Oh well nothing to do but wait.
    #2393
    Actually, you can also purchase other branded engine oils as long as these are dexos2 compliant. You can even use the SAE 0W-30 if you are living in Baguio, for example, since the 1st letter of the SAE mark is the temperature and also, mejo expensive ang 0W-30 compared to 5W-30 that are both dexos2.
    Maaaring tama si *numbah5, the SA gave you a mineral grade so that you will have to change oil every 5k
    *numbah5, how much naman daw ang per liter ng dexos2 SAE 5W-30 fully synthetic oil? Other ranges from Php550 to Php900 per liter and we are talking of 7-liter capacity engine ;(
    Aug 2004
    #2394
    Quote Originally Posted by bacs View Post
    baka naman warak kaagad sasakyan mo pagparati mong ginagawa 'to ....o di kaya i-void warranty mo??
    Jul 2006
    #2395
    Quote Originally Posted by jojo728 View Post
    800 pesos per liter. Also, please refer to my post at page 241 with the scanned images from the manual regarding the oil. Thank you.
    Jul 2006
    #2396
    Yup pwede 5W-40 basta Dexos2. Pero the manual specifically said the best viscosity grade for the Duramax Diesel engine is 5W-30.
    Scanned images from the manual:
    This is for all of us, for us to be enlightened about the engine oil. Especially *jojo728.
    #2397
    *numbah5, thanks for the reply. I already have the TB manual, kinulit ko lang ang Chevy Greenhills to give me an owner's manual.
    It's 800 per liter, then the dexos2 SAE 5W-30 engine oil will be Php 5,600.00 already, oil pa lang.
    Actually, ACDelco ang manufacturer nung Dexos2 SAE 5W-30, General Motors is the global supplier.
    #2398
    Correction lang sir.
    Cutoffs will still likely be affected by installing HIDs in projectors meant for halogen bulbs.
    Iba parin yung beam pattern niyan. The best non-retrofit upgrade for halogen headlights are still halogen.
    Posibleng mas maliwanag nga for the driver, pero kawawa yung mga kasalubong mo.
    Quoted from hidplanet.com:
    I would be cautious about putting HID's in halogen projectors because they will not likely have proper cutoff. I put an aftermarket set in my 2009 wrx (which had halogen projetors) and although the light output was significantly better than halogen bulbs, glare was terrible for oncoming drivers - those things would blind people on a highway overpass as I'm driving by on the highway. Took them out shortly after for safety reasons.
    There's a thread on this here if you guys want to do some extra reading.
    Based on reading the first few pages, parang mas panget din daw pala yung output.
    Jun 2009
    #2399
    Okey ,DEXOS is the recommended Engine Oil as what chevy people say, but what if it is not available, at least they should have a substitute brand, marami dyan na also well known for lubricant-(ex. penzoil ,mogul, castrol etc etc.) na readily available,
    #2400
    Quote Originally Posted by RTS View Post
    *RTS, it's all here:
    Licensed GM dexos2™ products (Look on the front label for any of the logos shown above to identify an authorized, licensed dexos2™ engine oil.):
    GM dexos information center
2012 Chevrolet Trailblazer
