Results 2,391 to 2,400 of 4415
- Dec 2012
- 293
January 28th, 2013 12:49 PM #2391
- Dec 2012
- 293
January 28th, 2013 12:50 PM #2392Just spoke to my agent... according to him 2nd week to last week of feb daw ang mga trailB colorado daw ang mga dumating mga pending pa daw dati yun(ang dami colorado sa mga showroom nila)... as an importer I find this shady. Oh well nothing to do but wait.
- Mar 2010
- 95
January 28th, 2013 01:38 PM #2393Actually, you can also purchase other branded engine oils as long as these are dexos2 compliant. You can even use the SAE 0W-30 if you are living in Baguio, for example, since the 1st letter of the SAE mark is the temperature and also, mejo expensive ang 0W-30 compared to 5W-30 that are both dexos2.
Maaaring tama si *numbah5, the SA gave you a mineral grade so that you will have to change oil every 5k
*numbah5, how much naman daw ang per liter ng dexos2 SAE 5W-30 fully synthetic oil? Other ranges from Php550 to Php900 per liter and we are talking of 7-liter capacity engine ;(
Tsikot Member Rank 3
- Aug 2004
- 2,452
January 28th, 2013 02:43 PM #2394
- Jul 2006
- 3,376
January 28th, 2013 03:05 PM #2395
- Jul 2006
- 3,376
January 28th, 2013 03:13 PM #2396
- Mar 2010
- 95
January 28th, 2013 03:21 PM #2397*numbah5, thanks for the reply. I already have the TB manual, kinulit ko lang ang Chevy Greenhills to give me an owner's manual.
It's 800 per liter, then the dexos2 SAE 5W-30 engine oil will be Php 5,600.00 already, oil pa lang.
Actually, ACDelco ang manufacturer nung Dexos2 SAE 5W-30, General Motors is the global supplier.
- Jul 2009
- 3,604
January 28th, 2013 03:26 PM #2398Correction lang sir.
Cutoffs will still likely be affected by installing HIDs in projectors meant for halogen bulbs.
Iba parin yung beam pattern niyan. The best non-retrofit upgrade for halogen headlights are still halogen.
Posibleng mas maliwanag nga for the driver, pero kawawa yung mga kasalubong mo.
Quoted from hidplanet.com:
I would be cautious about putting HID's in halogen projectors because they will not likely have proper cutoff. I put an aftermarket set in my 2009 wrx (which had halogen projetors) and although the light output was significantly better than halogen bulbs, glare was terrible for oncoming drivers - those things would blind people on a highway overpass as I'm driving by on the highway. Took them out shortly after for safety reasons.
Based on reading the first few pages, parang mas panget din daw pala yung output.Last edited by mda; January 28th, 2013 at 03:30 PM.
January 28th, 2013 03:33 PM #2399
Okey ,DEXOS is the recommended Engine Oil as what chevy people say, but what if it is not available, at least they should have a substitute brand, marami dyan na also well known for lubricant-(ex. penzoil ,mogul, castrol etc etc.) na readily available,
- Mar 2010
- 95
January 28th, 2013 03:42 PM #2400*RTS, it's all here:
Licensed GM dexos2™ products (Look on the front label for any of the logos shown above to identify an authorized, licensed dexos2™ engine oil.):
GM dexos information center
But it is a chinese vehicle you can get spare parts from lazada or shopee right?
2024 Manila International Auto Show APRIL 4-7,...
