How does this system fare with the flood, impervious?
Sent from my GT-P3110 using Tsikot Forums mobile app
Nalubog na ba sa baha tpms sensor, more than a foot deep flood?
Sent from my ONEPLUS A3003 using Tapatalk
nailusong ko na sa baha, mga half-tire deep (if it helps, nagkaroon ng tubig yung fog lamps ko dahil sa baha) gen1 crv.
naipa-underwash ko na rin. so far so good naman.
More than 2 weeks later, i have yet to charge the monitor pero 1 bar lang nabawas. It just relies on solar charging.
Btw, yung temperature monitor is probably not too accurate since i just realized it is outside the tire and not inside (mine is an external sensor). Dapat yung temperature inside ang minomonitor so mas okay sa part na ito yung internal sensors.
But pressure sensor is pretty accurate.
Finally had my TPMS installed and working as expected. [emoji4]
It monitors the temperature of the air inside the tires ... Same way it monitors the tire pressure ...
hello guys, any of you here uses indirect tpms? all I can see here is direct tpms. how about indirect? thanks
Bought an external sensor version of this TPMS for USD27 from Aliexpress. So far okay naman. Yung reading nya is around 1psi higher than what I expected. Hindi ko alam kung ang tama ay yung TPMS o yung tire pressure gauge na gamit ko hahaha
just a question po for those who bought their tpms sa lazada.
- gaano katagal yung battery ng sensors sa tire? and napapalitan din ba sila if empty na?
- if one sensor is missing, can you buy just the sensor lang or you need to buy the whole device?
I bought from Aliexpress (but wth, Lazada overseas sellers are basically the same entities as Aliexpress sellers)
-I've read it can last for at least a year.
-Yes, you can change the battery. Before, installing, I opened one unit to expose the battery. Pretty simple process at least for the Jansite brand I bought.
-nakakita ako ng isang external sensor but compatible lang isang brand. so I gues it depends sa brand kung magbebenta ng isang sensor. walang problem mawala pag internal sensor.
