Page 12 of 12 FirstFirst ... 289101112
Results 221 to 240 of 385
    How much was the sensor? Or you can replace just the battery of the sensor?
    Sa MS, the sensor is sealed and you cannot replace the battery. Pampapera talaga ng Winterswine ito
    Sa rim ata yung sensor Kasi Di ko naman pinalitan yun. Not sure how the TPMS works on the ASX but yung 3 valves pinalitan ko na.
    Ito ba yung mga sensors na naka-install sa loob ng rim? If so, how much did it cost you to replace one?
    Sa MS ko, I was quoted Php9,000 for a single replacement. I said forget it and went aftermarket. No regrets ever since.
    Kahit bagong external TPMS ang bibilhin ko taon taon, mura pa rin
    Same with me bro. After the batteries of the oem internal tpms sensors of our MS died after 2 years, I did not bother replacing them. I just bought a new set of tpms and its external sensors...
    Jul 2013
    Guys, any leads kung saan makakabili ng matibay na tire valve/pito (preferably online).
    Yung lock kasi ng TMPS ko ay nakaka strip ng thread ng barbula. Masyado malambot yung valve.
    Dec 2008
    Quote Originally Posted by Lew_Alcindor View Post
    Stainless tire valve sir mg ask ka sa mga auto shop meron nyan sa akin deretso ko na pinapalitan doon sa shop and tire balancing na rin medyo mabigat na kasi tire valve.. so far so good pag hinigpitan ko tpms di na sumasama tire valve. Yung dati kasi na rubber tire valve pag higpit ng tpms pg dimo kinontra medyo ma stress yung rubber tirevalve.
    Sent from my Nokia 7 plus using Tsikot Forums mobile app
    Jul 2013
    Quote Originally Posted by john042776 View Post
    Salamuchas gracias!
    The X3 has a built-in tpms and connects to the mid display.20221220_105317.jpg
    Ang salarin sa pag ngatngat Ng sensor Ng kotse. Maski tinakpan ko na Lang Ng electrical tape, may Plano pa din balikan ata Kasi tinabihan nya nanaman iyong gulong [emoji850][emoji29][emoji2959]
    Sent from my RMX3690 using Tsikot Forums mobile app
    a handsome, copper husky!
    try a physical cover against the tyre.
    plywood... discarded plateware... atbp.
    That she is doc. Very chewy Lang and domineering Siya among her pack mates. Hindi Lang Siya maka-ubra sa belgian melanois Namin. Talo Siya sa kakulitan eh [emoji38]
    "try a physical cover against the tyre.
    plywood... discarded plateware... atbp"
    Thanks for the tip
    Jan 2009
    Whew! Crisis averted.
    A few days ago, during an out-of-town trip, I noticed that one sensor stopped updating and by the end of the day, the display for that sensor went dark. Typically, the latter happens when the battery inside that sensor runs out. The other three tires were still reporting temperature and pressure values so it's unlikely to be a problem with the receiver.
    So that night, I took out the nonresponsive sensor and replaced the CR1632 with a new one. I know it's a new battery because I tested it first before installing it and it showed around 3.3V.
    The next morning however, the sensor reading for that tire is still blank. So I removed it again and checked the battery. To my disappointment, the voltage is now down to 2.5V! So the sensor is draining the battery somehow. A closer inspection does not reveal any water intrusion. I always use silicone grease on the O-ring and the cap threads so it's simply impossible for water to get in.
    So long story short, I started tearing into the tiny PCB. Since it's dead anyway, I can't make it any worse. I just blindly re-flowed the solder on everything on there. It's a challenge as everything is so tiny. I reassembled everything and inserted another new battery and screwed it back on the tire.
    About 2 hours later, I went back to check the TPMS receiver and I was elated to see that the "dead" sensor is now sending data again.
    I don't know if this is going to be permanent but I'm hoping that it is. I guess these sensors are subjected to unimaginable abuse.... them being on the tires and all, so maybe a cold solder developed. Anyway, time will tell if the fix holds. I'm just glad I don't have to replace the whole TPMS. Not yet anyway.
    Thanks for the tip
    Meron nabibili sa Lazada na tire cover.
    ^ Oo nga ano. Sana Nakita ko ito dati pa.
TPMS (Tire Pressure Monitoring System)
