Page 4 of 12 FirstFirst 12345678 ... LastLast
Results 61 to 80 of 385
    ^ i've bought 2 tpms machines from lazada already and they're both equipped w/ an option to choose whether you'd prefer using psi or bar units of measurements. I think it's already an industry standard.
    We finally got to make it work
    here's the external sensor screwed on the tire valve
    Mar 2004
    What model is this? ...
    Pershn u912fhonda
    I Bought it from lazada
    Apr 2006
    hindi ba sobrang laki at conspicuous yung mga external sensors?
    Quote Originally Posted by wewoy_romero View Post
    yan din ang iniisip ko. pero mukhang ok naman sa pictures si bro baludoy eh.
    Jul 2013
    actually ang inaalala ko, baka masira kapag piltin ng mga istambay/tricycle drivers na tanggalin.
    Was looking for an actual installed picture of this for the longest time. Thanks for sharing
    Apr 2006
    dumating ngayon yung inorder ko from shopee. for around 2k pwede na. the sensors are a little larger than i thought and sana wala na yung chinese characters. the monitor is usb powered and also solar powered. looks okay naman. will install later.
    Apr 2006
    haaay bakit ganun? ayaw gumana ng upload image?
    Jan 2017
    any reco what type/where to have it installed for mux?
    ^ try mo via tapatalk. Download mo iyong old version
    Apr 2006
    so far so good. when installed the sensors record 1psi higher than my trusted analog tire gauge. driving around taguig to bgc for a few minutes in slow traffic, umakyat ng 1psi mga tires with the front tires going up first.
    the temperature sensors are a little too sensitive for my taste pero it means it is accurate. initially sa parking before leaving, one tire was warmer by 1c. which might be true kasi yun yung naaarawan. going to bgc, the two passenger side tires are always 1-2c higher given sila yung side ng araw. akyat-baba ng akyat-baba by 1-4c every few seconds depending on how i drive. pero checking sa covered parking kanina, nagpantay na silang lahat.
    yung monitor turns off after no motion for a few minutes. pag naka-detect ng motion (ex, door is opened or tinapik mo yung sasakyan), nag-oon yung monitor. never plugged it in. relied on solar power and so far palagi naman full bar yung battery indicator. sana tumagal yung battery sa sensor.
    user's manual is very hard to understand. ang liit ng sulat, broken english pa. kinapa ko na lang kung paano isetup. may 2 parts lang na di ko ma-gets regarding tire pairing and kapag nag-rotate ka ng tires (might as well just rotate the sensors para di nakakalito).
    di naman madaling nakawin. unless you have that wrench that comes with it or pipilitin mo, which in case, masisira mo yung sensor or yung pito.
    only concern ko now: is it heavy enough to affect tire balance? sana in the future they can make it smaller para less conspicuous.
    Jan 2013
    Question lang sir...
    So it comes with its own wrench to remove it? Pano kung mawala mo yung wrench? At need to remove? Kelangan sirain na yung pito?
    Sent from my ONEPLUS A3000 using Tapatalk
    Quote Originally Posted by remzam View Post
    You can buy the wrench sa handyman or true value... ordinary lang uung wrench...
    Ganyan lang, i think long nose kaya yan...
    Jan 2013
    Ah ok sir. Akala ko proprietary wrench. Generic naman pala. So walang problema. Got it!
    Mahihirapan kang tangalin yung nut with that kind of wrench. Meron steps yung wrench para dyan para di sumabit sa mags. Di mo kita yung nut pag tatanggalin mo siya.
    Good choice sir! Same tayo... easy to set-up...
    And can be powered by solar...
    Only way to find out is to run the car at high speed. Kapag nanginig that means the balance has been upset
    Sir, where did you buy this and how much? I know you posted this sometime ago, so can you give us some feedback whether it is still working, in good condition, etc...
TPMS (Tire Pressure Monitoring System)
