Page 7 of 20 FirstFirst ... 3456789101117 ... LastLast
Results 121 to 140 of 385
    #121
    Quote Originally Posted by wewoy_romero View Post
    hindi ba sobrang laki at conspicuous yung mga external sensors?
    yan din ang iniisip ko. pero mukhang ok naman sa pictures si bro baludoy eh.
    Jul 2013
    #122
    actually ang inaalala ko, baka masira kapag piltin ng mga istambay/tricycle drivers na tanggalin.
    Apr 2006
    #123
    interested ako especially i do once a month long drives.
    for daily city driving, i do weekly tire check and i think that is enough.
    before long travel, i check tires. pero ang concern ko is during the long drive i want to feel secured na hindi umiimpis ang gulong in case mapako ako or what. may mga areas kasi na hindi maganda ang daan in between high speed roads. so i want to make sure na bago mag-highway ulit, ok pa ang gulong ko after going through some rough road.
    i prefer sana yung external para easier maintenance, pero yung nga natatakot ako na since malaki, baka mainit sa mata at pilitin nakawin.
    Dec 2009
    #124
    Hi, any recommended external tpms with anti theft feature? Thanks
    Dec 2017
    #125
    Quote Originally Posted by jvo View Post
    This one needs a wrench to "unlock" it. Still, not "theft proof".
    https://www.lazada.com.ph/products/z...Eb01b&search=1
    Mar 2004
    #126
    They won't steal them because it would look weird on their rides ...
    #127
    We finally got to make it work
    here's the external sensor screwed on the tire valve
    Was looking for an actual installed picture of this for the longest time. Thanks for sharing
    Apr 2006
    #128
    dumating ngayon yung inorder ko from shopee. for around 2k pwede na. the sensors are a little larger than i thought and sana wala na yung chinese characters. the monitor is usb powered and also solar powered. looks okay naman. will install later.
    Apr 2006
    #129
    haaay bakit ganun? ayaw gumana ng upload image?
    ^ try mo via tapatalk. Download mo iyong old version
    Apr 2006
    #131
    so far so good. when installed the sensors record 1psi higher than my trusted analog tire gauge. driving around taguig to bgc for a few minutes in slow traffic, umakyat ng 1psi mga tires with the front tires going up first.
    the temperature sensors are a little too sensitive for my taste pero it means it is accurate. initially sa parking before leaving, one tire was warmer by 1c. which might be true kasi yun yung naaarawan. going to bgc, the two passenger side tires are always 1-2c higher given sila yung side ng araw. akyat-baba ng akyat-baba by 1-4c every few seconds depending on how i drive. pero checking sa covered parking kanina, nagpantay na silang lahat.
    yung monitor turns off after no motion for a few minutes. pag naka-detect ng motion (ex, door is opened or tinapik mo yung sasakyan), nag-oon yung monitor. never plugged it in. relied on solar power and so far palagi naman full bar yung battery indicator. sana tumagal yung battery sa sensor.
    user's manual is very hard to understand. ang liit ng sulat, broken english pa. kinapa ko na lang kung paano isetup. may 2 parts lang na di ko ma-gets regarding tire pairing and kapag nag-rotate ka ng tires (might as well just rotate the sensors para di nakakalito).
    di naman madaling nakawin. unless you have that wrench that comes with it or pipilitin mo, which in case, masisira mo yung sensor or yung pito.
    only concern ko now: is it heavy enough to affect tire balance? sana in the future they can make it smaller para less conspicuous.
    Jan 2013
    #132
    Question lang sir...
    So it comes with its own wrench to remove it? Pano kung mawala mo yung wrench? At need to remove? Kelangan sirain na yung pito?
    Sent from my ONEPLUS A3000 using Tapatalk
    Good choice sir! Same tayo... easy to set-up...
    And can be powered by solar...
    Quote Originally Posted by remzam View Post
    You can buy the wrench sa handyman or true value... ordinary lang uung wrench...
    Ganyan lang, i think long nose kaya yan...
    Jan 2013
    #135
    Ah ok sir. Akala ko proprietary wrench. Generic naman pala. So walang problema. Got it!
    #136
    Only way to find out is to run the car at high speed. Kapag nanginig that means the balance has been upset
    Aug 2014
    #137
    hmm kala ko kaya may wrench para hindi manakaw, pero kung generic and madali mabili, ibig sabihin kahit sinong may wrench na ganyan pwede kunin yung tpms? hehe
    Jan 2013
    #138
    Quote Originally Posted by ericb View Post
    Yun rin akala ko. Kahit plais kaya ikutin kung gusto.
    Yes pero hindi nila basta2 magagamit kasi need din ang receiver... it will just somehow make harder for magnanakaw to steal the tire cap... kaya advise ko din park sa safe na lugar...
    Jul 2018
    #140
    Hi. New to the forums here. I have a set of stock TPMS from my Mitsubishi Pajero 2014. After tire rotation at a gas station, the TPMS monitor onscreen went blank as in "--.--" in all tires. How can I reset or recalibrate the TPMS? Also, I think its brand is AVT.
TPMS (Tire Pressure Monitoring System)
