Page 5 of 12 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 385
    Yes pero hindi nila basta2 magagamit kasi need din ang receiver... it will just somehow make harder for magnanakaw to steal the tire cap... kaya advise ko din park sa safe na lugar...
    Jul 2018
    Hi. New to the forums here. I have a set of stock TPMS from my Mitsubishi Pajero 2014. After tire rotation at a gas station, the TPMS monitor onscreen went blank as in "--.--" in all tires. How can I reset or recalibrate the TPMS? Also, I think its brand is AVT.
    Quote Originally Posted by HashKetchup View Post
    As far as i know, each sensor has a label on which wheel its supposed to be installed. Front left, back left, etc) you have to swap these sensors to where the wheel actually is currently.
    Apr 2006
    More than 2 weeks later, i have yet to charge the monitor pero 1 bar lang nabawas. It just relies on solar charging.
    Btw, yung temperature monitor is probably not too accurate since i just realized it is outside the tire and not inside (mine is an external sensor). Dapat yung temperature inside ang minomonitor so mas okay sa part na ito yung internal sensors.
    But pressure sensor is pretty accurate.
    Dec 2009
    How does this system fare with the flood, impervious?
    Sent from my GT-P3110 using Tsikot Forums mobile app
    it's holding up pretty good on our 2 vehicles. no issues in heavy rain nor in slow moving, trafficky flood prone streets.
    Jul 2013
    Bought an external sensor version of this TPMS for USD27 from Aliexpress. So far okay naman. Yung reading nya is around 1psi higher than what I expected. Hindi ko alam kung ang tama ay yung TPMS o yung tire pressure gauge na gamit ko hahaha
    Aug 2018
    just a question po for those who bought their tpms sa lazada.
    - gaano katagal yung battery ng sensors sa tire? and napapalitan din ba sila if empty na?
    - if one sensor is missing, can you buy just the sensor lang or you need to buy the whole device?
    Jul 2013
    Quote Originally Posted by Xotigu View Post
    I bought from Aliexpress (but wth, Lazada overseas sellers are basically the same entities as Aliexpress sellers)
    -I've read it can last for at least a year.
    -Yes, you can change the battery. Before, installing, I opened one unit to expose the battery. Pretty simple process at least for the Jansite brand I bought.
    -nakakita ako ng isang external sensor but compatible lang isang brand. so I gues it depends sa brand kung magbebenta ng isang sensor. walang problem mawala pag internal sensor.
    Quote Originally Posted by Lew_Alcindor View Post
    Sir, how much is this? Are the caps (tama ba yung desciption ko?) not prone to being stolen?
    Jul 2013
    Quote Originally Posted by attyallanlatras View Post
    Nabili ko ng US$26.39 sa Aliexpress.
    (I suggest comparing prices sa Lazada, Shopee and Aliexpress. The unit I bought is almost half the price of those being sold in Lazada.)
    IMO, kahit may "lock" nut, madali siyang manakaw. Pero wala naman silbi kung nakawin nila yung external sensors.
    Nasa Laguna kami so hindi ganun talamak ang nakawan. Pero lumuwas na din ako ng ilang beses sa Metro Manila. Hindi naman nawala.
    Mar 2018
    Nalubog na ba sa baha tpms sensor, more than a foot deep flood?
    Sent from my ONEPLUS A3003 using Tapatalk
    Quote Originally Posted by RavenBlack View Post
    No problem, sealed yan TPMS. Meron o ring sa loob pag binaklas mo.
    Apr 2006
    nailusong ko na sa baha, mga half-tire deep (if it helps, nagkaroon ng tubig yung fog lamps ko dahil sa baha) gen1 crv.
    naipa-underwash ko na rin. so far so good naman.
    Mar 2018
    Thanks.
    Aug 2009
    Finally had my TPMS installed and working as expected. [emoji4]
    Mar 2004
    It monitors the temperature of the air inside the tires ... Same way it monitors the tire pressure ...
    Aug 2010
    hello guys, any of you here uses indirect tpms? all I can see here is direct tpms. how about indirect? thanks
    ^i've been using the same device for our truck since april of last year.
    I bought it at lazada and so far there hasn't been any problems.
    Aug 2018
    I was just about to ask you since I saw your review for that device in Lazada. Thanks! Haha
    Sent from my SM-A530F using Tapatalk
TPMS (Tire Pressure Monitoring System)
