Results 1 to 10 of 39
- Jan 2013
- 1,851
February 3rd, 2017 01:24 AM #1Keyless entry for cars are becoming a norm these days.
I'm just curious, what happens if you have your key inside your pocket and you leave the car while the engine is running? Will the engine stop or will it continue to run?
Maybe different cars will have different behaviors.
Sent from my ONEPLUS A3000 using Tapatalk
- Jul 2016
- 939
February 3rd, 2017 04:13 AM #2
- Jun 2015
- 2,751
February 3rd, 2017 07:33 AM #3Engine keeps running. Alarm system won't let you lock the doors from outside. There's only an alarm to let you know the key is out of range.
Actually, someone can just hop in and drive the car away if you leave it like that. Once the thief shuts off the engine, however, there's no way to start it up without the key (immobilizer and all that).
Key fobs usually have a VERY short range. You'd have to be standing almost in front of the door's lock button for you to unlock/lock the door. That means no one can sneak up and unlock the doors behind your back as you are walking away. The car can also tell if the key fob is inside or outside the vehicle so you can't turn on the engine even if the key fob is close by but not inside the cabin.
I'd suggest you try to download the owner's manual of the particular vehicle that you're interested in.
Tapatalked
February 3rd, 2017 08:28 AM #4
I think this should be "cars with auto start" or something and not "cars with keyless entry"?
_/_/_/
31.7K _/_/_/_/_/_/_/_/_/_/
February 3rd, 2017 09:41 AM #5
- Jun 2015
- 2,751
February 3rd, 2017 09:51 AM #6^
Perhaps the more expensive ones. I'm just relating how mine behaves from experience. There have been times when my wife carries the keys in her bag and forgets to hand it over to me as she alights to open our garage gate. I haven't tried driving far without the key but there's nothing in my owner's manual that indicates the engine will shut itself down.
I also doubt that cars will be designed to shut down when it loses contact with the key fob transmitter. What if the key fob battery runs out while you're cruising on the highway? That'd be potentially disastrous.
Tapatalked
- Jun 2012
- 4,447
February 3rd, 2017 01:13 PM #7What happens if you throw out your key (fob) WHILE driving ? Don't be stupid enough to do this.. - YouTube
Sent from my SM-A9000 using Tapatalk
- Oct 2009
- 2,271
February 3rd, 2017 03:28 PM #8
February 3rd, 2017 03:55 PM #9
mas madali daw nakawin yang may push start, all they need is a blank key fob, an obd scanner and they can re-program a new code sa blank key fob.. is this also happening here sa atin?
- Jul 2016
- 939
February 3rd, 2017 05:21 PM #10Forgot that running out of battery and ruiningbyour long weekend vacation or highway experience.
A more serious problem is carbon monoxide poisoning. There were reported deaths already linked to keyless entry nakakalimutan patayin engine as OP stated .
Keyless entry vehicles linked to deaths - YouTube
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
