Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
    Nov 2016
    #21
    You cannot lock the door if the key fob is inside. Even if you put it in the trunk, and try to close it-- it will repel.
    Since you haven't driven a keyless entry car, why not see one of your friends car?
    Mar 2004
    #22
    Quote Originally Posted by Offroad_Goals View Post
    Given the situation above, kahit naka-lock na yung mga pinto mo but the key fob is inside the vehicle, pag pinindot ba nila yung "unlock" button sa door handle, magbubukas pa din?
    The door can't be unlocked from outside if the key fob is inside the vehicle ... but does it really make a difference if there's only a piece of glass in between a gun and your head?
    #23
    Quote Originally Posted by jk ranad View Post
    I'm planning to buy a mirage gls model...kaso naguguluhan ako if gls ang pipiliin ko...because of the push button stat/stop engine...pag nasira po ba yun malaki po ba ang cost? pwede ba hindi gamitin ang push button? may alterantive key po ba sa mirage na talaga gagamit ka ng susi?
    it's just a button, po.
    just as the susian is just a susian.
    i personally find the susi-to-start better. that way, i don't get to misplace the key. but i suppose it's still users' discretion.
    in the late 50s-early 60s, push start was de reguer
    buyna!
    Jun 2012
    #24
    buyna!
    I agree. If my friend drives my car, im 100% sure na nasakanya ang susi pagbaba namin dahil traditional key. Whereas if i drive his car na push start, i always ask him o nasa sayo ang susi ah. Baka magkasalisihan kami e
    Sent from my SM-A9000 using Tapatalk
    Apr 2017
    #25
    buyna!
    Maraming salamat po Dr. D
    Apr 2017
    #26
    buyna!
    Salamat sa inputs
    Jun 2012
    #27
    Can be unlocked using the door combination lock. On some models.
    Jun 2012
    #28
    Quote Originally Posted by RR_22 View Post
    Not for all cars with keyless entry, but I can lock my car's door using the handle touch pad. I usually leave the key inside and I open it with the door combination lock. What I hate bringing the key is that I have a manner of pulling the door handle to check if the door is locked. It will open again!
    Mar 2004
    #29
    Use the rear door to check if the doors locked ...
    Sep 2016
    #30
    Ah. I see. Thanks for the input sir. Will definitely try!
    Sep 2016
    #31
    Thank you for the input sir! Will definitely try a keyless entry vehicle and just see for myself. Btw sir, yes it does po especially if the windows are bulletproofed, but then again if it won't unlock if the key fob is inside than that's a good feature.
    But just a random thought again, will it be impossible for to jump start a manual transmission vehicle with a push start/stop system?
    Jun 2012
    #32
    Just like any other car, you can jump start it.
    Mar 2004
    #33
    Actually, one should avoid jump starting vehicles with sensitive electronics ... there are certain vehicles that should not be jump started ...
    #34
    oo nga naman...
    i don't have one, so i am curious...
    how does one turn on the engine electricity in these cars?
    Jun 2012
    #35
    oo nga naman...
    The Keyless Entry circuitry is always on monitoring the key fob. Activating the Keyless Entry will turn ON/OFF the accessories circuitry including the push start system.
    May 2017
    #36
    I think it will stop. Because I didn't seen any car is running without a key.
    Aug 2017
    #37
    It is not impossible but, can be very dangerous, the engine might knok, so why try?
    Jan 2009
    #38
    There's really no to very low risk of anything that could go wrong as long as:
    1. The polarity is correct
    2. The system voltage of thw two vehicles are identical
    3. The cables are installed with the ignition switch off
    It's really no different than connecting an outbord battery charger to the vehicle or plugging in a jump-start power brick through the cig lighter socket.
    #39
    ... will it be impossible for to jump start a manual transmission vehicle with a push start/stop system?
    will you please clarify your question?
    1) if you are referring to using jumper cables from donor car battery ... or
    2) you are referring to push-start the "manual" car to start the engine?
    If case 1, using jumper cables will work on both "manual" and "matic" cars
    If case 2, yes it is possible, as the push/start button can TURN ON the engine electricals without starting (e.g. if you don't step on the brakes) on the second push. The first push will only turn on accessories. So basically, the button behaves like the conventional key switch. The third push wil return to OFF.
Cars with Keyless Entry
