Results 31 to 39 of 39
- Sep 2016
- 50
May 5th, 2017 01:27 PM #31Thank you for the input sir! Will definitely try a keyless entry vehicle and just see for myself. Btw sir, yes it does po especially if the windows are bulletproofed, but then again if it won't unlock if the key fob is inside than that's a good feature.
But just a random thought again, will it be impossible for to jump start a manual transmission vehicle with a push start/stop system?
May 5th, 2017 01:55 PM #32
May 5th, 2017 06:34 PM #33
Actually, one should avoid jump starting vehicles with sensitive electronics ... there are certain vehicles that should not be jump started ...
- 52,698
May 6th, 2017 01:24 AM #34
May 6th, 2017 01:47 AM #35
- May 2017
- 7
May 9th, 2017 06:12 PM #36I think it will stop. Because I didn't seen any car is running without a key.
- Aug 2017
- 9
August 28th, 2017 03:35 AM #37
August 28th, 2017 08:09 AM #38
There's really no to very low risk of anything that could go wrong as long as:
1. The polarity is correct
2. The system voltage of thw two vehicles are identical
3. The cables are installed with the ignition switch off
It's really no different than connecting an outbord battery charger to the vehicle or plugging in a jump-start power brick through the cig lighter socket.
Tsikot Member Rank 4
- 2,716
September 15th, 2017 10:59 PM #39will you please clarify your question?
1) if you are referring to using jumper cables from donor car battery ... or
2) you are referring to push-start the "manual" car to start the engine?
If case 1, using jumper cables will work on both "manual" and "matic" cars
If case 2, yes it is possible, as the push/start button can TURN ON the engine electricals without starting (e.g. if you don't step on the brakes) on the second push. The first push will only turn on accessories. So basically, the button behaves like the conventional key switch. The third push wil return to OFF.
One dude told me it was Li-Ion. Another dude corrected him. AFAIK the Zenix gets the Li-Ion hence...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
