Results 71 to 80 of 89
August 26th, 2019 12:14 PM #71
CTEK is a huge name among smart car chargers. Blade auto center carries it. They also sell Sparco smart car charger. That's the one I bought at 2,500 pesos. It only has 1.2 amps so "slow and low" charging ito. You can leave it overnight and you don't need to detach your car battery. Safe on the car's onboard electronics since it has 1.2 amps only.
- Oct 2019
- 30
November 6th, 2019 06:29 AM #72
- Jan 2019
- 3
August 15th, 2021 02:23 PM #73
August 19th, 2021 11:43 AM #74
hanap ka kapareho nito sa shopee or lazada
ok ito kasi qc 3.0 na (if android user ka)
Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
- Jan 2008
- 4,726
August 19th, 2021 04:59 PM #75correct sir.. and many batteries like the philippine national battery (moto) will display "12 volts" but will not have enough juice to drive the starter motor..
ilang beses na din kami nadale nyan.. umuwe ng haus good cranking power pa.. next morning wala na..
pwede din bumili ng battery tester.. yung electronic type.. based on my experience, na detect nya kung nasa end stage na yung battery..
- Jan 2008
- 4,726
August 19th, 2021 05:05 PM #76yan sparco nga.. maganda din yung charger nila.. kaso masyado mababa for me yung 1.2 amps.. kaya nag settle ako sa ctek at 5 amps..
meron din yung NOCO genius or Bosch C7.. for me mas maganda yung medyo mataas na amps.. para kung sa umaga eh medyo kinapos ng power, pwede ka mag charge saglit para maka start.
August 19th, 2021 05:31 PM #77
I have that Bosch C7. 7 amps sya. Nginuya ng dog yung wiring, thankfully only the insulation was damaged and still working after I patched up the insulation. Big help in maintaining our car batteries since I hardly use our cars now.
- 54,225
August 20th, 2021 07:44 AM #78in-ability to start the engine due to dying battery, can and usually occurs overnight.
"battery looks strong when garage-ing the car that night... can't start the car the next morning."
i have a basic battery charger (local panther, 5 amp capacity lang).
when the battery is too weak to start the engine, i just charge it for 15 to 30 minutes, just so's i can start the car.
then my next destination is the battery store.
buti na lang, the store is conveniently nearby.
i am also master of push-start, if the car is MT.
August 20th, 2021 10:06 AM #79
I keep a number of the nearest battery store, they usually deliver and install naman sat your house. A lot cheaper than those 24/7 delivery service.
- Jan 2008
- 4,726
August 20th, 2021 10:56 AM #80some batteries usually shows signs eh... like sa 2 past amaron ko.. but with motolite wala sign.. malakas nung umaga.. kinabukasan totally dead na.. tik tik tik na starter..
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
