Results 41 to 50 of 88
April 26th, 2018 08:04 PM #41
Update ko lang ito.
Battery 1 year and 10 months (tumagal pa ng 2 months).
Sobrang hirap na talaga mag start mga nakaka 5 pihit ako ng susi bago bumukas engine.
Car voltometer from Lazada showing that the battery is normal (12+ engine off, 14+ engine on).
Pumunta na ako mekanino kasi baka iba sira, they check the battery with battery tester ba yun? Sa kanila ang reading 10+ na lang pag engine off and told me na mag palit na ng battery. Di ako nasa satisfy and punta ulit iba naman mekaniko, same reading, same recommendation, palit batt na talaga.
Does it mean hindi reliable itong mga car voltometer na ito?
April 26th, 2018 08:16 PM #42
Just the battery voltage alone is not a reliable measure of battery capacity.
Compare the battery to a low level water tank, even with good pressure ( from the pump), it cannot SUSTAIN the electrical load. The voltage is the electrical pressure, the ability to sustain (current) is the amount of water in the tank.
What I have been doing is loading the battery while checking the voltage. A simple way to do this is to disable fuel delivery and crank the engine a few seconds while observing the battery voltage. If the voltage drops below 11 volts while cranking, change the battery and repeat the test. If the voltage still falls below 11 volts, replace the battery.
April 27th, 2018 12:00 AM #43
Will this kind of test do good for newer cars? From what I understand, you disable the fuel pump by removing the fuse. Is that right? For cars equipped with PCM and with almost all controls relying to computer, will it not give you code error once you disabled your fuel pump?
From what I've read, you can do your own battery voltmeter by connecting two series resistors and parallel it to one resistor. That series parallel resistors should serve as your probe as you connect it to your multimeter. I haven't tried it so I can't remember the values of resistors.
April 27th, 2018 06:17 AM #44
I have used this procedure on MY 2018 cars without adverse effects. Or, if you don't feel comfortable with this concept, remove the ECU fuse while load testing the battery. Or, bypass the starting circuit with the ignition switch off and crank the engine while observing the voltage. Whichever applies to your car, that's what you use.
April 27th, 2018 06:35 AM #45
Any shops out there with this or equivalent?
Google Image Result for https://i.ytimg.com/vi/LriNo7PwwoM/hqdefault.jpg
April 27th, 2018 08:41 AM #46
- 52,514
April 27th, 2018 09:27 AM #48
April 27th, 2018 09:29 AM #49
- 52,514
April 27th, 2018 09:34 AM #50
Traffic!
