Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 51 to 60 of 89
    Dec 2017
    #51
    Gomen nasai neh!
    It's supposed to read " charge the battery and retest"
    You guys are amazing... the first time I read it, it "sounded wrong" to me but I couldn't figure it out.
    Regarding the multimeter, that seems old school and I think it I saw that one in a very old video tutorial. I might be wrong...
    #52
    the friendly motolite outlet i go to, has one. they routinely use it when i drive over for battery replacement.
    i suppose all their branches have one...
    Dec 2017
    #53
    Quote Originally Posted by robot.sonic View Post
    Bumili ako ng bagong elm327 kaso napansin ko na pag matagal nang nakasaksak sa obd2 port ay nagkaka check engine ako. Happened twice. Nung di ko na kinabit ay di na umulit. Baka nakaka interrupt sa communication system ng oto.
    This is a good update. So it's better to use a voltmeter or perhaps get an "expensive" scanner.
    Jan 2017
    #54
    This happened to me last Dec.2017, voltmeter reading 12.5 (engine off) and 14.1 (engine running).
    Pansin ko hirap na mag-start sa umaga, what i did was the old school way of testing the battery., which is turn-on the headlight, crank the engine.
    Eh nag-blink na yung headlight ko, so ayun napabili ako ng battery ng wala sa oras. Sabi ko nalang sulit na rin battery ko which is almost 2.5 years na din.
    Dec 2017
    #55
    Quote Originally Posted by RaGa View Post
    This works for models that allows you to turn on the lights with the engine off. For some models, you won't be able to turn on the headlight if the engine is off.
    Jan 2017
    #56
    I agree
    Mar 2004
    #57
    Maybe one can turn on engine ... turn on headlight ... turn off engine ... then restart after a minute or so ...
    Dec 2014
    #58
    What if sira starter, can you still jump start it? If not, any other way para ma on engine?
    Mar 2004
    #59
    Push start ... literally ... only if it's a manual transmission ...
    #60
    if the battery still has some power left in it, but not enough to turn a starter, and your car is MT,
    you might still be able to start it, even if you do not charge the battery.
    "push-start", as stock says.
    we were doing it on a regular basis, years ago, when we couldn't afford a new battery.
Car Voltometer?
