Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 89
    Ito iyong vintage ko na voltmeter sa isa naming sasakyan
    bagay kasi red led niya sa red light na emit ng instrument cluster kaya hindi ko pa pinapalitan [emoji3]
    Aug 2012
    #22
    Quote Originally Posted by JJB View Post
    Maganda yang VST voltmeter. Have it in 1 car.
    Amazon din or lazada?
    D3 Technologies Makati. FB *d3techph.
    Sent from my ASUS_X00DDA using Tapatalk
    #23
    These are the old LED voltmeters that I have:
    I ran variable voltages into them so that I have an idea on the range of voltage measurements for a set of LED lights.
    I have long switched to digital displays with two USB chargers for our rides' voltmeters.
    Dec 2014
    #24
    Got mine already mga sir! Got it from lazada
    Naitapon ko lang yung box and yung battery reference
    Ok pa ba battery ko?
    Engine off - 12.7
    Engine on - 14.5
    Also, ok lang ba iwan naka plug ito? di kaya ma drain battery?
    #25
    Engine off - 12.7
    Engine on - 14.5
    12.7v means your battery is healthy.
    14.5v is good charging. Are all your accessories on? Headlights, air-conditioning Et Al.?
    If you turn off the ignition and pull the key out, the display is off, right?
    Then, no drain on the battery.
    Dec 2014
    #26
    Thanks sir CVT!
    Mag 2 years pa lang naman battery medyo worried lang kasi thrice a week lang nagagamit oto and short distance lang lagi.
    Nov 2014
    #27
    I have that voltmeter, accurate naman. Dun sa local seller recommended by red_one. Checked it against the device they use in casa to measure battery health (dunno what it's called), same naman ng reading. I bought three, gave the two as gifts, and after 1.5 years okay pa naman lahat (except yung napunta sakin na may ibang lines sa dispay na napundi na--di na nababasa yung last digit after the decimal point).
    Dec 2009
    #28
    Voltmeter to monitor the health of ur battery and alternator
    Thermometer to monitor the health of ur aircon system
    Simple, yet useful tools on the road
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Aug 2012
    #29
    Thanks sir CVT!
    Want to keep your battery healthier? Get an automatic car battery charger. Recondition your battery once a week. It is just plug & play.
    Quote Originally Posted by red_one View Post
    No need to disconnect or bring down the batt bro?
    Aug 2012
    #31
    Yes, no need to disconnect or remove the battery.
    Dec 2017
    #32
    Just connect it and leave it alone. I bought this one and have been using it everyday (I mean, during night time).
    Dec 2014
    #33
    Is this normal?
    Pag mga 1 day ko di ginagamit oto and unang pihit ng susi to turn on the engine ayaw, laging sa second try pumapasok. Akala ko tuloy lagi ubos na battery.
    Voltomete showing
    12.4 engine off
    14.6 engine on
    nangyayari lang pag matagal di binubuksan makina.
    Battery is 1 year and 8 months pa lang.
    #34
    Is this normal?
    Voltomete showing
    12.4 engine off
    14.6 engine on
    perhaps something else, and not the battery, is the cause.
    check the starter and solenoid, for two.
    #35
    Agree
    Sounds to me like a starter problem.
    #36
    to add,
    i had starter intermittent issue before.
    it was traced to the starter solenoid.
    ask ng mechanic, "puede hong linisin lang."
    sabi ko, "palitan nyo na. baka pa bumalik , isang hantinggabi, sa gitna ng wala. hindi naman gaano ka-mahal."
    Dec 2014
    #37
    Thanks mga sir.
    Ilang years pinapalitan ang starter kung casa PMS susundin?
    Mine is a 3 years Honda car. 15k pa lang odo.
    Mar 2004
    #38
    Starters lasts a really long time ... 10-15 years or more than 100T kms ... depending on use ...
    #39
    yespo.
    maraming starters, na-overhaul na ang makina, orig pa rin ang starter.
    yung starter solenoid ang pinapalitan.
    at yung bushing.
    Sep 2008
    #40
    Quote Originally Posted by blacksilver323 View Post
    Same here from Lazada. Compared to our multimeter directly measured from battery & alternator, may kaunting difference lang around 0.2 V if I am not mistaken.
    Same here, I have a difference of 0.2 V compared to the digital multimeter directly measured from the battery
Car Voltometer?
