Page 94 of 176 FirstFirst ... 4484909192939495969798104144 ... LastLast
Results 1,861 to 1,880 of 3510
    Oct 2009
    #1861
    Quote Originally Posted by Lew_Alcindor View Post
    AFAIK, a high amp charger should not be a problem. The amp rating is the max it can provide. The actual current (amp) that will drawn from the charger depends on your device.
    If you have a 1A device plugged in a 3A charger, that charger will supply only the required current (amp).
    Am I right?
    exactly..kung ano lang ang kayang kainin amperahe ng gadget mo. un lang ang ibibigay sa kanya.remember sa amperahe lang yan.sa voltahe hindi pwede kailangan sakto.
    Jul 2013
    #1862
    Quote Originally Posted by battouter View Post
    nice nice. now where to find the G1W-CB. kimstore has that G1W.
    Apr 2010
    #1863
    are the ones from Qube dashcams good?
    Aug 2005
    #1864
    Quote Originally Posted by myas110 View Post
    I use Qube x-cam A7 on my two vehicles. Video quality pretty decent (day/night).
    #1865
    Among today's dashcams, which ones can I stick to my car's rain sensor housing?
    I can't use a bike mount (like in my other car) because the rearview mirror stalk is too short. I also don't want to use a suction cup on my windshield. I tried different adhesives but none of them stick on the rain sensor housing because it's not a smooth surface - even my 3M automotive adhesive tape doesn't work (though it works very well for my shark fin antenna on my roof).
    What are my options? I'm looking for a discrete dashcam (Transcend is a definite no-no). It should also have better nighttime video quality than the SJ4000.
    I'm looking at the Mini 0805 but I don't know if the adhesive will stick. Though since it's small, I don't mind sticking it on the windshield directly. It's currently out of stock in Lazada. Are there other places where I can buy it, and how much?
    The Mini 0806 seems to have better low light capabilities, but is it available here?
    Any other suggestions are welcome. Thanks! [emoji5]
    Jun 2012
    #1866
    Nov 2015
    #1867
    I use Thinkware for my car. Its mounted via 3m adhesive. Mine is F550 model though
    #1868
    Quote Originally Posted by confused shoes View Post
    Thanks for the suggestion. But I believe this is mounted via suction cup, and its as bulky as the Transcend dashcams, so I'll have to pass on these.
    I'm looking for adhesive-mounted dashcams that are the same size as the SJ4000 or smaller.
    Quote Originally Posted by asamante View Post
    Looks great but it's way out of my budget. Trying to stay under 7k.
    Between the Qube Xcam A7 and Mini 0805, which is a better buy?
    I'm having difficulty sourcing a Mini 0805. Looking to buy by this week. All the Mini 0805s in Lazada will take at least 3 weeks for delivery.
    Apr 2010
    #1869
    Read somewhere na they both use the same hardware. I bought the A7 and no problems with it so far, I am using its own cigarette socket power supply; camera socket is mini-USB. I used the suction mount on the rearview mirror, ayaw ko kasi nang may nakadikit sa windshield. I can still use the mirror, at the same time mas madali mag baklas-kabit when parking.
    May unboxing ako several pages back
    #1870
    Just a thought, maybe I can use the SJ5000+ as well, using the supplied helmet mount.
    So basically - Mini 0805 vs. Xcam A7 vs. SJ5000+
    Which has the best nighttime video quality?
    #1871
    subscribing. will wait kung alin kukunin ni Jut
    Nov 2015
    #1872
    I'm not an expert on these matters but between Qube Xcam A7 and Mine 0805, i choose the latter. It fits all your requirements. I guess you'll just have to wait a little longer w/ Lazada
    #1873
    Will try to drop by Qube later, hopefully may available na A7. If it's too big, might wait for the 0805.
    Apr 2006
    #1874
    tried that approach with my sj4000. it won't last long. didikit siya tapos pag nabilad sa araw, unti-unting mag-sag until mahulog na. i even replaced the adhesive with 3m heavy duty mounting tape (yung black na ginagamit sa car accessories like rain gutter), di umubra. natatanggal din eventually. maybe it is because of the non-smooth surface of the rearview mirror.
    #1875
    * jut
    does strapping the mount with the rain sensor housing with black zip-ties isn't feasible?
    #1876
    Quote Originally Posted by wewoy_romero View Post
    How did you mount your SJ4000 then?
    I'm thinking if hindi kaya sa rain sensor, adhesive nalang sa windshield. More stable than the suction cup I think. Though I plan to put it on the dot matrix part para hindi visible.
    Quote Originally Posted by benchman View Post
    * jut
    Zip ties will not be stable and looks cheap. I want to keep it as clean as possible.
    #1877
    Walang stock ng Xcam A7! [emoji30]
    And then yung mga Mini 0805 na nasa Lazada, all of them are imported, so I don't know if the products are really available, and if I will be able to return/replace the product in case it's defective. The only local supplier of the Mini 0805 doesn't have stock either.
    To A7 and 0805 users, hope you can help point me to suppliers with stocks. Thanks!
    Apr 2010
    #1878
    Marami branches ang Qube, meron 2 within the vicinity of Gilmore. Have you called the branch before going in? Yun ang isa pang gusto ko sa X-Cam, may storefront and warranty claims should be easier.
    I believe they accept shipping but haven't tried it, check their website
    #1879
    may optional GPS logger and speed display yata yung A7. mukhang maganda add on ito.
    Apr 2006
    #1880
    i gave up and used suction cup on the windshield. since naka-medium tints naman ako, hindi halata. hindi talaga pwede sa rear view mirror ng gen1 crv eh.
Blackbox DVR/Dashcam
