Page 93 of 117 FirstFirst ... 4383899091929394959697103 ... LastLast
Results 1,841 to 1,860 of 3510
    Jun 2012
    Quote Originally Posted by miguel20 View Post
    Guys pwede bang gawing dashcam ang action cam? For dual purposes kasi eh hehhee.. ano mai recommend niyo mga bossing?
    Sent from my SM-N920S using Tsikot Forums mobile app
    I'm using SJCAM SJ4000Wifi.
    About 1 year and 4 months na sya. Lagi lang sya naka kabit sa kotse. Once ko pa lang ginamit as action cam.
    Aug 2012
    If it serves its purpose, then it is not a waste of money. Kaya ako naglagay ng hard wire is para maging free ang 12v cigarette lighter port and also to make wiring tidy or invisible. Which is yun nga ang naging result.
    The fuse is optional. Yup, mababa lang ang current load ng dashcam. Kaya naman ako gumamit ng fuse tap is para madali ang installation. Just tap to the fuse box.
    Sent from my ASUS_Z010D using Tapatalk
    Jul 2013
    Quote Originally Posted by red_one View Post
    I am not referring to the hard wiring as a waste of money but rather the hard wiring kit. You can hardwire it without a hard wire kit or with a must less expensive fuse tap.
    Ako mismong planning to hardwire for the same reason as yours. Pero na-realize ko unnecessary expense yung hardwire kit na ginamit mo. But anyway, your money, your rules.
    Aug 2012
    Quote Originally Posted by Lew_Alcindor View Post
    It is money well spent for me.
    Not everyone needs a hardwire kit but to say that we are wasting money is rude. Imho.
    Jul 2013
    I don;t know what is rude with saying that. It is an opinion. Anyway, read my post again. I already said "your money, your rules".
    Nov 2015
    nevermind him, probably he isn't well informed of what your dashcam is capable of.
    the hardwire kit still draws power even when your engine/acce mode is off, your dashcam has gsensor/motion detect capabilities and can record even on park mode
    and auto power cuts off depends on the setting on put on it.
    Walang hardwire kit yung sakin, nakarekta lang din sa ignition and may fuse din. 300 lang kasama na labor.
    SJ4000 WiFi going on 3 years now.
    Jul 2013
    Ito yung sinasabi ko. No hardwire kit necessary.
    Jul 2012
    hardwire kit is needed for 5V dashcams. kelangan kasi yung 12v to 5v adapter, hindi pwedeng rekta.
    Jul 2013
    Quote Originally Posted by skylightpigeon View Post
    yan din akala ko. pero ang balak ko tap from fuse box then connect to power adapter that comes with the dash cam. that out-of-the box power adapter surely converts 12v to 5v, right?
    Jul 2012
    in my case kasi, besides sa nakakahinayang sirain, mas abala kung didistrongkahin ko pa yung cigar lighter adapter na kasama sa dashcam para ma-hardwire. tsaka yung hardwire kit na ginamit ko USB type A port, so possible na gamitin sa iba ibang type nang cable kung may bagong dashcam man akong gamitin other than mini USB type port. its more of a permanent and OEM approach to hardwiring dashcams. not necessary, but definitely not a waste of money. in my opinion.
    I just used the charger that came with the dashcam. That already converts 12V to 5V.
    Jul 2012
    is it a cigar lighter port type of charger? if so, how did you hardwire the adapter to the fuse box without disassembling the adapter?
    We dissambled the adapter.
    Jul 2012
    i imagine a PCB or coils to convert voltage is inside the housing? i would not know where to tap +/- wires if that is the case.
    Jul 2015
    maybe its the weather
    Jul 2012
    does your adapter look like that?
    lahat ba ng dashcam may auto off ang screen habang nagrerecord?
    To those who are using DP220, has anyone experienced the time changing on its own? Example I set the time to 18:00, after few minutes, magiging 10:00 siya.
    That happens to me also. Di ko alam pano irectify...
    Sent from my SM-G930F using Tsikot Forums mobile app
Blackbox DVR/Dashcam
