Among today's dashcams, which ones can I stick to my car's rain sensor housing?
I can't use a bike mount (like in my other car) because the rearview mirror stalk is too short. I also don't want to use a suction cup on my windshield. I tried different adhesives but none of them stick on the rain sensor housing because it's not a smooth surface - even my 3M automotive adhesive tape doesn't work (though it works very well for my shark fin antenna on my roof).
What are my options? I'm looking for a discrete dashcam (Transcend is a definite no-no). It should also have better nighttime video quality than the SJ4000.
I'm looking at the Mini 0805 but I don't know if the adhesive will stick. Though since it's small, I don't mind sticking it on the windshield directly. It's currently out of stock in Lazada. Are there other places where I can buy it, and how much?
The Mini 0806 seems to have better low light capabilities, but is it available here?
Any other suggestions are welcome. Thanks! [emoji5]
I use Philips ADR610.
Philips Dashcams : The ADR61 & ADR81 go head to head - YouTube
I use Thinkware for my car. Its mounted via 3m adhesive. Mine is F550 model though
Thanks for the suggestion. But I believe this is mounted via suction cup, and its as bulky as the Transcend dashcams, so I'll have to pass on these.
I'm looking for adhesive-mounted dashcams that are the same size as the SJ4000 or smaller.
Looks great but it's way out of my budget. Trying to stay under 7k.
Between the Qube Xcam A7 and Mini 0805, which is a better buy?
I'm having difficulty sourcing a Mini 0805. Looking to buy by this week. All the Mini 0805s in Lazada will take at least 3 weeks for delivery.
Read somewhere na they both use the same hardware. I bought the A7 and no problems with it so far, I am using its own cigarette socket power supply; camera socket is mini-USB. I used the suction mount on the rearview mirror, ayaw ko kasi nang may nakadikit sa windshield. I can still use the mirror, at the same time mas madali mag baklas-kabit when parking.
May unboxing ako several pages back
Just a thought, maybe I can use the SJ5000+ as well, using the supplied helmet mount.
So basically - Mini 0805 vs. Xcam A7 vs. SJ5000+
Which has the best nighttime video quality?
I'm not an expert on these matters but between Qube Xcam A7 and Mine 0805, i choose the latter. It fits all your requirements. I guess you'll just have to wait a little longer w/ Lazada
Will try to drop by Qube later, hopefully may available na A7. If it's too big, might wait for the 0805.
tried that approach with my sj4000. it won't last long. didikit siya tapos pag nabilad sa araw, unti-unting mag-sag until mahulog na. i even replaced the adhesive with 3m heavy duty mounting tape (yung black na ginagamit sa car accessories like rain gutter), di umubra. natatanggal din eventually. maybe it is because of the non-smooth surface of the rearview mirror.
* jut
does strapping the mount with the rain sensor housing with black zip-ties isn't feasible?
How did you mount your SJ4000 then?
I'm thinking if hindi kaya sa rain sensor, adhesive nalang sa windshield. More stable than the suction cup I think. Though I plan to put it on the dot matrix part para hindi visible.
Zip ties will not be stable and looks cheap. I want to keep it as clean as possible.
Walang stock ng Xcam A7! [emoji30]
And then yung mga Mini 0805 na nasa Lazada, all of them are imported, so I don't know if the products are really available, and if I will be able to return/replace the product in case it's defective. The only local supplier of the Mini 0805 doesn't have stock either.
To A7 and 0805 users, hope you can help point me to suppliers with stocks. Thanks!
Marami branches ang Qube, meron 2 within the vicinity of Gilmore. Have you called the branch before going in? Yun ang isa pang gusto ko sa X-Cam, may storefront and warranty claims should be easier.
I believe they accept shipping but haven't tried it, check their website
may optional GPS logger and speed display yata yung A7. mukhang maganda add on ito.
