Page 93 of 176 FirstFirst ... 4383899091929394959697103143 ... LastLast
Results 1,841 to 1,860 of 3510
    #1841
    My SJ4000 is 1.5 years old and I leave it in the car, plugged in 100% of the time.
    Be sure to use a low-amp charger to avoid overheating. Most car chargers have 2A ratings, some even have 3A. My SJ4000 is routed directly to my ignition (not cigarette lighter port), using a 1A charger.
    Aug 2005
    #1842
    Quote Originally Posted by noone09 View Post
    Tinry ko na ibang battery kasi 2 battery ko nun. Pati ibang charger. Umiilaw parin yung red indicator light pag chinarge. Pag pinress paulit ulit yung power button umiilaw parin yung blue light. Dinisassemble ko na rin pero di ko alam kung ano aayusin dun. I even tried na nakasaksak lang usb charger na walang battery. Red light lit up but still won't power on.
    Mag 1 year old palang yung akin.
    Kung yung sayo sir nakasaksak all the time at ok parin. Ano kaya naging cause ng failure nung akin. Iniisip ko nung pag start ko ng kotse sobra sa 12v yung dumerecho sa camera kaya nasira.
    Same behavior with my Qube A7. At first I thought I messed it but somehow it worked again after resetting the unit. I found out the culprit was dueibg cold starting with the cam directly plugged in to the lighter port. Kill switch lang ang kinabit ko. Problem solved. So whenever i re start engine, I switch off the modified switch first. After the engine settled from a cold start, switch the cam on with the modified switch.
    Nov 2014
    #1843
    Ok din kapag may rear camera. At least alam mo ang nangyayari sa harap at likod.
    Oct 2008
    #1844
    Quote Originally Posted by Alex Tamayo View Post
    Sir, anong dash cam gamit nyo?
    Jul 2013
    #1845
    AFAIK, a high amp charger should not be a problem. The amp rating is the max it can provide. The actual current (amp) that will drawn from the charger depends on your device.
    If you have a 1A device plugged in a 3A charger, that charger will supply only the required current (amp).
    Am I right?
    #1846
    Should be, if the device pulls just the right voltage. It's just that I don't trust the china-made SJCAM's circuitry, nor do I trust most car chargers.
    Apr 2015
    #1847
    Anung dash cam gamit mo? Free installation ba yan? Ung tago ang wirings?
    Sent from my LG-H818 using Tsikot Forums mobile app
    Nov 2014
    #1848
    Quote Originally Posted by lowiejee View Post
    Anytek T1 ang gamit ko. Bought this last May. DIY lang ang cabling at mounting na ginawa ko. I'll post pictures later this afternoon.
    Pros: 1080p; wide angle; has park mode; front and back cam
    Cons: Turns on when you start engine but does not record automatically; low-res rear camera.
    Verdict: good enough for my need.
    More sample videos:
    Front Anytek T1 highway drive - YouTube
    Rear SUV stealth mode - YouTube
    #1849
    Hello mga sirs!
    Need some help lang. Finally decided to get a dashcam. I'm torn between transcend dp220 and the numerous anytek models nalilito na nga ako.
    Okna sana yun dp220 kaso price is around 5-6k na. Are there anytek or comparable cheaper models?
    Thanks in advance.
    Feb 2011
    #1850
    Mga boss ito project ko sa dashcam ko. Useless kc parking mode ng mga dashcam, Di nagtatagal...pano kung binangga ung car mo sa parking lot na di mo namamalayan o wala nakakita.
    Oct 2009
    #1851
    Hello mga sirs!
    Thanks in advance.
    Wala.
    Yung mga Anytek na dashcam hindi malinaw ang video. Hindi yan totoong HD, makita mo naman ang video quality sa mga uploads sa youtube.
    Mas malinaw pa yung mga G1W type na dashcams.
    Just buy transcend. There is a reason why it is expensive.
    #1853
    Thanks Battouter and Dreamer! Will follow advice at transcend na nga.
    Sent from my SM-N910C using Tapatalk[/QUOTE]
    Aug 2010
    #1854
    Mukhang ok din xiaomi..
    May english/international version na kaya dito sa atin?
    #1855
    Wala pa ata sir. Most online sellers have the chinese version. Got one and it's indeed a bang for the buck
    Sent from my MI 3W using Tapatalk
    Nov 2014
    #1856
    Quote Originally Posted by battouter View Post
    Wala.
    Anytek T1 gamit ko. HD and malinaw naman siya.
    Oct 2009
    #1857
    luma na hardware nyan at mukhang interpolated lang ang HD resolution. halata naman dahil hindi sharp images nya.
    mas malinaw pa ata ang mga G1W.
    Aug 2005
    #1858
    Readable ba plates ng incoming and trailing vehicles at night?
    Oct 2009
    #1859
    Nov 2014
    #1860
    Quote Originally Posted by leinahtan View Post
    I have some sample daytime and night time videos sa Youtube channel ko. Though limited ang night videos, what I observed is that hindi ko na readable ang plates kapag malayo and kapag natapatan ng ilaw. Also, with 24 fps, unless na mabagal ang takbo ng sasakyan, blurred ang mga letters. Furthermore, it does not help that my car has dark 3M tint.
    But with just 2,500 I get decent front camera for daytime driving and a synced rear camera to cover my back and to also help in backing-up. It has usable parking mode and since it clips to my rearview mirror, less clutter on my windshield.
    If you have the money, check out the other recommendations and hopefully it will satisfy your needs.
    Good luck.
Blackbox DVR/Dashcam
