Results 121 to 130 of 758
February 11th, 2008 11:23 AM #121
Sorry double post
February 11th, 2008 11:24 AM #122
Are the Garmin Nuvi series available sa pinas?
Can the lowest model (nuvi 200 ata) handle the philippine roadmap?
February 11th, 2008 10:00 PM #123
Loaded the latest map of carlos into my garmin nuvi 350. Currently using it here in Manila. Works great.
February 12th, 2008 01:50 AM #124
February 12th, 2008 02:00 AM #125
nakabili pala ako dito sa saudi ng NUVI 310 v4 at middle east maps lang pero pweding lagyan ng SD card para sa ibang maps... i try ko nalang i download ang pinas maps then pag uwi ko tingnan ko kung omokey dyan.
February 12th, 2008 04:35 AM #126
I have a TOM TOM which has a SD card slot, if I were to download a Philippine map from http://mapcenter2.cgpsmapper.com, will it work? or are these just for Garwin units?
February 12th, 2008 06:02 AM #127
AFAIK pwede ka namang mag-install at mag-browse ng Philippine map basta kasya pa sa memory card mo. Hindi ka nga lang ituturo ng GPS sa Pinas kasi wala ka naman duon.
Magkano ang kuha mo sa Nuvi 310? Malaki na ang ibinagsak ng presyo ng mga satnav's dito sa UK. Presyong-ginto dati ... ngayon makakakuha ka pa ng "libre", tulad ng kapag bumili ka ng post-paid cellphone.
February 12th, 2008 06:11 AM #128
- Dec 2007
- 142
February 12th, 2008 07:46 AM #129where can we buy these kinds of gps nav system here in the philippines?
- Feb 2008
- 3
February 12th, 2008 04:44 PM #130yes the maps at http://www.freewebs.com/phroadguide are compatible with latest nokia's. google on a how to (garmin mobile xt)
You are more then welcome to start working on above mentioned poi's, send them to us at ph.roadguide * gmail . com and we'll update the maps with them.
address search is not working on the newer garmin units (yet). hopefully the new compatible compiler will be released shortly and should take care of that problem. In the meantime, i made another map which allows you to search streets as a poi. (map to be released soon, still testing it).
cheers,
phroadguide
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
