Page 11 of 12 FirstFirst ... 789101112 LastLast
Results 201 to 220 of 231
    Jul 2004
    #201
    Quote Originally Posted by miko101130 View Post
    Malayo talaga sir ang output ng retrofit compared sa bolt on.. Depende pa din yun sir sa plano nyo with your ride.... Pero i don't think na meh gusto bumalik from retrofit to stock again. Hehehe...
    Nasubukan ko na po kasi yung g5 na bolt on and hindi ako satisfied kaya i went the retrofit way... And talagang very useful sa driving.
    he's talking about aftermarket projector headlights, yun palit buong assembly, which has bad output compared to the bolt on projectors that you are saying.
    I think of most of the aftermarket projector headlights are so bad, mas malakas pa output ng stock reflector headlights.
    Dec 2009
    #202
    Kung projector headlight assembly na buo na agad, i would agree nga na mas malakas pa output halogen basta philips ang bulb mo...
    Masasayang lang pera tapos malungkot ka pa sa output....
    i suggest sir na tignan po nyo yung mga output pics nang na iretrofit na para ma gauge nyo kung saang path gusto nyo tahakin...
    But based sa experience ko, its either retrofit or halogen... Opinion lang.. Hehehe...
    #203
    yep tama si glntVR, yung ganito
    Buti na lang di pa ko bumili, I was thinking na mas makakamura ako dito vs retrofit. Thanks sa advice!
    Dec 2009
    #204
    maporma yan sir, pero mas maganda ouput nang retrofit...
    kasi kung plano nyo pala ibenta ang kotse, mahirapan kayo upgrade dahil laging mang hinayang...
    it would be up to you sir kung retrofit o yang bolt on ehadlight assembly...
    pero IMO and based from experience, malayo ang performance and safety na mabibigay ng retrofit...
    #205
    I see. 10k lang kasi ang budget ko pero gusto ko yung q5 para wala na upgrade upgrade, high end na agad. Hehe
    #206
    hello po sa lahat! bago ko lang nalaman na mali pala yung pag ugrade ko to hid kit since i need a projector headlight pala. I have a hilux 2009. Magagamit ko pa ba yung hid kit ko na nabili if projector headlight nalng ang bilihin ko? or mas better if pa retrofit nalang? thanks po sa inyong tulong.
    Dec 2009
    #207
    Quote Originally Posted by beni23 View Post
    Yes sir, sa Q5, maganda na talaga output nyan, for the 15k price sulit siya sir, pag na upgrade nyo yan with the retrofit, im sure hindi na talaga kayo babalik sa halogen.... Very safe and very good ang light output and dimensions...
    I did my own retrofit sa eve namin... I bought my Q5 from sir ginnova, and did the mods my self, natuwa talaga ako with the output... Wide and long light output. You can really never go wrong with projectors..
    Aug 2011
    #208
    Mga sir question lang po, ano maganda brand ng hid ( regular ballast or slim ballast)? Any recommendation na mabibilhan ng hid na subok na? TIA
    #209
    ^Regular ballast na HID kit ang kunin mo sir. Yung Genesis (China, slim ballast) malakas ang return rate so iwas ka sa brand na yun.
    Dec 2009
    #210
    i also preferred the thick ballasts... bulky nga lang pero parang mas tatagal sila eh... more space to dissipate heat...
  11. #211
    the only reason why thick ballasts are thick is because the ignitor is housed together with the main body of the ballasts. Thin ballasts have ignitors mounted separately. A good quality ballast, either thick or thin will last a long time and have a low failure rate.
    Aug 2011
    #212
    Thank you sir
    Aug 2011
    #213
    Quote Originally Posted by garyq View Post
    How about sir gary yung slim digital ballast? Same ba yun sa slim type lang? How about yung fluctuation? Thanks sir gary
    Dec 2009
    #214
    before 2 set ang ballast meron ako, 1 pair is china na 55 watt ballast slim type...
    after a couple of weeks, meh konting flickering sa start up... so pinalitan ko na lang agad..
    2 pairrs thick ballast na nagamit ko before and hindi naman nagloko yung mga ballast so far..
    pero siyempre as time goes by, there will improvements in terms of quality of the capacitors and other components inside the ballast
    pero na observe ko even the OEM ones like Denso, matsushita, even the morimotos are thick in construction unlike the more common china type slim ballasts.. though denso calls their ballast slim pero parang malaki pa din eh..
    Aug 2007
    #215
    very informative thread.. although i kinda got lost in the technical explanation.. i just got a bnew sorento which has a low halogen projector fitted with h7 bulb and a hi halogen reflector. i'm planing to upgrde the low to hid. can simenw enlightne me on what i am to expect should i upgrsde... will it have the same quality as a retrofit projector. TIA
    Sent from my AT100 using Tapatalk 2
    #216
    Quote Originally Posted by sagingsaba View Post
    Definitely not. Iba ang HID projectors sa HALOGEN projectors. It will have a better cut off than ordinary reflector bowls, pero it won't have the same output as what you see on garyq's threads as the ones you have are made for halogens only not HIDs
    Aug 2007
    #217
    but will the hid/ halogen projector combo be better in terms of light output than the original halogen projector ?
    Dec 2009
    #218
    I highly doubt sir... Kasi if your projectors are designed for halogen bulb pag nag hid ka, mas magmumukang intense lang yung color,, medyo scientific lang, pero iba kasi ang focal point ng halogen bulb versus sa hid bulb, therfore hindi mo talaga ma compare it to retrofit which specifically are made to utilize and maximize the light from the hid bulb...
    #219
    Mas liliwanag syempre kasi naka-HID ka. Mas intense yung ilaw ng HIDs compared sa halogens. Pero yung light throw etc., can't compare with HID on HID projectors.
    #220
    Mabuti nalang kamo yun mga headlights ng bagong Sorento at SF medyo malapit sa cutoff ng projector HID.
Things to know when upgrading to HID
