Onga Nighthawk, eh. Nalaman ko kay Ken na di ka na nagreretro.![]()
yep, gotten so much busy since the start of the year.
ganun pala pag Chief operating officer.![]()
sir nighthawk, need to send you Pm, but you need to clear some old messages first, thanks
mga boss,
yung park light po ba, kung papalitan ko ng blue bulb,ano po dpat ang specs ng bulb na dapat kong ipalit??thanks po in advance!!!
guys ano difference nung g3 g5 and g6 na projector?
any comments on these?
http://www.**************/index.php/...s=h4+projector
majority of the differences will be in the BOWL, LENS, CUT OFF SHIELD which will create different light output/intensity/distribution/throw-out.
g6 is the enhanced version of the g5(same spec), you can change the angel ring color(not possible with g5)
g5 has a better light dispersion and cutoff than previews versions. more focused.
g3
comparison of cut off
sir NighthawkGT,
pa pm naman kung magkano yung package for the toyota corolla ae111.?
thanks
sir ung sa honda civic po 96 model,magkano po un? ano po ba un buong headlight bilhen ko ung ung stock ko na lng na hallogen tapos iset up na lng?pm me sir,thanks
good info po sir marami po kasi na naka hid na masabi lang na naka hid kaya kalat ung ilaw talaga at lalo na pagkasalubong mo.
Sir NH. I am interested mag pa install sa inyo nghid. Mitsu adventure 2012. Pks contact me po 09228252959. Tnx
Sir, yung sa stock fog lights ba pwede i replace agad ng super white bulbs, or ireretrofit pa din yun?
go with projectors, its the only path sa pag upgrade HID... no glare, maximum light on the road....
What about the output of aftermarket projector headlights vs retrofit? Mas mura kasi pag bibili na lang ako nung buong headlight for strada na aftermarket, hindi pa bubuksan yung headlight ko and I get to keep it para pag ibebenta na yung sasakyan pwede ko pa ibalik sa stock, pero ang hindi ko lang sure is yung buga niya baka naman mahina.
Malayo talaga sir ang output ng retrofit compared sa bolt on.. Depende pa din yun sir sa plano nyo with your ride.... Pero i don't think na meh gusto bumalik from retrofit to stock again. Hehehe...
Nasubukan ko na po kasi yung g5 na bolt on and hindi ako satisfied kaya i went the retrofit way... And talagang very useful sa driving.
