Results 11 to 20 of 231
- Jan 2008
- 70
January 20th, 2010 11:56 AM #11Great post sir. Question lang po, mazda3 is already fitted with projectors correct? So if i switch to HID, maganda and tama po yung buga?
Thanks
January 20th, 2010 01:11 PM #12
its case to case paren, some halogen projectors respond well to hid's but some are not. its better to test it paren in actuality and compare outputs.
as for the mazda3, the one im seeing on the roads have not so good output pattern. some of the owners are relying on clear lens swapping to further improve the cut off sharpness, but still, the width stays the same.
for the top of the line mazda3 2.0, it sports xenon projectors already, thats why beam patterns are quite different.
and ofcourse the definition of good pattern is quite subjective. ako kasi im spoiled with high end projector outputs e. hehe
- Jan 2008
- 70
January 20th, 2010 02:17 PM #14
Was planning to just slap in a pair of bulbs sa stock lens na pang halogen, now I know better. Anyone who has an idea kung magkano projectors for Corolla AE101?
January 20th, 2010 02:27 PM #15
Nighthawk,
could you post a picture ng beam ng projectors kapag nilagay sa non clear HL? visible pa ba ang cut off?
TIA
January 20th, 2010 04:07 PM #16
we have not yet retrofitted a headlight with fluted lens pa. since surely the cut off will scatter. anyway i'll try to find my old fluted lens and direct a projector there and take a pic. that would much say if how blurry the cut off will get. baka this weekend siguro pag may time na.
January 20th, 2010 07:56 PM #17
January 20th, 2010 08:03 PM #18
if its plastic then sanding it would be another alternative, but its veryvery difficult to do that. the next problem is after sanding it, it gets blurred out, and its hard to polish it again and again to be as clear as the real thing.
we tried this once and we gave up
January 20th, 2010 08:37 PM #19
Very informative thread
sana sticky ng mods
This thread made me (and my dad) understand some facts about HID..Ang akala kasi ng dad ko perwisyo palagi ang HID sa ibang drivers dahil karamihan ng nakikita niya plug and play lang sa Stock Halogen headlamps.. Pero ayaw pa rin ata niya sa HID
So 4300k is the best? White po ba ang color nito? Magkano po kaya ang aabutin including retrofitting ng headlights ng Civic EK?
January 20th, 2010 08:54 PM #20
HID when not correctly used will result to glare tlaga.
4300k is the brightest bulb out there. yellowish white ang output color. the pictures posted above all are running 4300k OEM philips bulbs.
for the ek you got PM
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
