Ganda nung nasa AE92. Fit na fit.
*hiromi.
yup.shot from sm sucat parking.
- - - Updated - - -
*hiromi.
Complete HID Projector Upgrade for the FORD Explorer 2012, the first shop to offer this:
Headlight Projector Upgrade:
Foglight HID Projector upgrade:
Output fogs only:
hidretrofit.net >> in the forefront of HID projector retrofits and led lighting innovation
What are the differnce among stage 1 2 3?
Sent from my Galaxy S using Tapatalk
mikki: pls check out my website: HIDRetrofit.net - HID Projector Retrofits | LED Lightning Innovation
ako: not yet but same lang internals lang ng previous model. Halogen projectors, very familiar with how Honda mounts halogen projector. Straightforward lang retrofit nyan.
- - - Updated - - -
mikki: pls check out my website: http://www.hidretrofit.net
Hi GaryQ,
Just saw this post. Can you PM me how much to retrofit headlights of a 2006 Honda Civic 1.8. and a 2010 Nissan X-Trail. Pls include options. My main reasons for adding more light is really just to see more at night especially on drives in the province along long stretches of road. Aside from a brighter headlight, will the retrofit provide a longer and wider distance of light? How much longer and wider? However, can you do the retrofit without producing a lot of glare as this is one of the major causes of accidents in the provinces. Are you open on weekends? Thanks
Will PM you. The main reason for a retrofit is to allow you to use the higher output of an HID (high intenstity discharge) bulb without causing glare to other motorists. HID bulbs will produce 3x more light than your stock halogen bulb so you can expect that improvement. I have never encountered anyone na ginawan ko who even considered going back to halogen. Retrofit is the perfect solution for you especially for provincial trips. Madami na rin ako na-retrofit na ganyan ang situation. Pls wait for my PM
Hi Gary, do you have a picture of DRL or alternative lighting that can be mounted on 2012 CX9 foglamps area? Just to get an idea before I go to your shop to have it installed.
Thanks.
Sir Gary, i am planning to retrofit my Nissan Grand Livina. Ito sana yung gusto kong set up.
Stage 2 Retrofit 3" projectors *in Cooper or Gatling or New F2 *custom mat/flat silver finish shroud, D2s *aftermarket setup, *50w, 4300 kelvin
I am Not so familiar with the specs so paki correct na lang if possible yung gusto kong set up. Pa pm na din how much aabutin para mapaghandaan ko. Thanks
Nga pala 2 members of our Livina Club have there cars retrofitted by you si Sir Bobot and Si Sir Dexter. I was impress nung nakita ko yung gawa mo.
chualie: retrofitted those Livinas. Sent you a PM na.
Some projects lang over the holiday season:
The all new Mazda BT50 4x4, same platform ng Ranger na bago. Complete lighting upgrade for the headlights and fogs.
did several Altis 2012 last week, fresh from the casa. Eto yung isa, stage3 HL plus fogs
ano mas maganda for fogs? projectors on hid o stock halogens?
in consideration sana with how bad our weather can get and how thick fogs can be...yung wide sana at malayo ang bato, with yellow light ayaw ko kasi ng fogs na whitish o yung common na hid....
- - - Updated - - -
hid stock halogen projectors will not give you a considerable increase in output. hid on stock halogen hl is a no-no coz of the glare. For what car?
- - - Updated - - -
If you are asking for fog application: the projectors that I use for fog application, many times has better light output than the stock halogen headlights!
- - - Updated - - -
