Results 1,981 to 1,990 of 2382
- Jun 2013
- 38
September 21st, 2013 01:56 AM #1981Hi sir,
I was the one who texted before. I would like to ask if this can be done. Something like the post of arki_j on the other thread.
http://tsikot.com/forums/hyundai-car...ml#post2027997
For my white Accent Hatchback.
- Dec 2002
- 2,335
September 22nd, 2013 10:50 AM #1982coolgrease: yes pwede natin gawin yan pero we will use oem projectors. bolt on yan mga ganyan na setup, output and reliability malayo sa oem setup.
OEM SMDs for my tail light retrofitsLast edited by garyq; September 22nd, 2013 at 11:27 AM.
- Dec 2002
- 2,335
- Dec 2002
- 2,335
October 1st, 2013 12:22 PM #1985SIR never goes out of style, hehe.
unique aftermarket HL with HID projectors retrofitted and also first time for the 70mm fog setup to get mounted on the EK body.
- Sep 2012
- 7
October 2nd, 2013 10:18 PM #1986sir gary ask ko lang po kung magkano para sa montero sport 2013. kc naka projector headlight n papalitan lang b ng bulb un or babaguhin lahat? ska how much pag head light lang? ska kung s foglight magkano din po. thanks.
- Dec 2002
- 2,335
October 5th, 2013 05:16 PM #1987Our first Honda City 2013 GM Full LED retrofit.
Retrofitted on "like new" set of OEM tail lamps
using: OEM leds for park (driving) and brake functions
with led side markers:
park or driving lights ON
brakes ON
Decided to re-design the lighting function vs. the original. In my opinion mas "pansin" during braking na meron set of lights turning ON vs. light na nag increase lang sa intensity. Also yung clear lens na part nung TL maganda lagi naka ON sa park lights kasi pansin na LEDs and the long led bar naman, we installed high intensity LEDs for brake function. I love the way this turned out. Bagay na bagay sa GM, I think.
- Feb 2012
- 30
October 6th, 2013 12:45 PM #1988Thanks uli sir gary for the work on my accent HB, 50mm foglight hid projector retrofit plus wiring work for the 2014 spec OEM projector headlights w/ DRL :D
Galing ng wiring work nila, oem spec ang dating...best wiring work ive seen so far compared to other shop's wiring work when installing aftermarket accessories
October 6th, 2013 01:04 PM #1989
Sir gary, have you done e36 bmws? Could you post pic? Tnx
Sent from my G-Note 2
October 6th, 2013 11:44 PM #1990
The assumption that the vehicle runs on the road, the ECU is more than likely a match. Try cleaning...
***HELP*** iding problem
