Results 21 to 30 of 65
- Aug 2003
- 91
April 27th, 2004 10:28 AM #21ask ko lang.... ano magandang socket sa headlight bulb madali kasi lumambot yung socket ko... para sa crv old model thanks
April 27th, 2004 02:43 PM #22
You can use ceramic sockets inplace of stock plastic headlight sockets. But before you change them, better make sure there are no loose wirings that causes your plastic sockets to melt. Have an expert check all the headlight wirings to be sure.
April 27th, 2004 11:12 PM #23
mayroon Bosch na headlight sockets na gawa sa ceramic. di na kailangan ng spade terminals just strip a few mm of wire and stick it in their respective slots. spring loaded ang mga connections niya.
- Aug 2003
- 91
April 29th, 2004 11:36 AM #24salamat po.... meron bang polarity ang headlight baka kasi magkamali ako eh
April 29th, 2004 11:50 AM #26
sundan mo nalang sa dati
kung alin ang left/right na nakatayo at yung isang nakahiga
April 29th, 2004 12:55 PM #28Originally posted by pentot2
...meron bang polarity ang headlight baka kasi magkamali ako eh
April 29th, 2004 05:39 PM #29Originally posted by ssaloon
magkano yung nasa xenon bulbs booth?
You can also check www.xenon-bulbs.com for bulb models for each car. HTH.
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
