Halogen bulb comparison chart against OEM halogen bulbs.
BulbFacts | Halogen Bulb Chart - Comparing Halogen Bulbs in Reflector Headlights
good day, not sure if applicable in here. Currently using depo headlight for my EE90, replaced the stock koito (which is old enough) with bosch H4, same rating as the stock, 60watts something. Question is, meron pa po ba better bulb that i can use? i saw the PIAA bulbs but not sure if the depo can handle the heat even with same rating. Talo ng kasalubong and other lights pag nasa city. But pag nasa dark places, tolerable naman. But still, better to have brighter ones.
Thanks
Saw one at Blade Auto Center last week.
PIAA HYPER ARROS 3900K 12V 65W
PIAA Hyper Arros H9 39 K 12V 65w Bulb HE-9 5 – blade.ph
got this for 1.1k
old stock yata, a bit whiter than stock. tbh i dont see the 25m advantage over stock, and frankly im worried if ok fog penetration kung sakali maabutan ako
Pegasus Halogen 4300k H4
Windshield Medium Tint
Came from H4 LED. Tumagal lang ng 4 months.
Sent from my Redmi Note 5 using Tapatalk
Good morning sirs! Has anybody tried the philipps H4 led bulbs on their vehicles?
Saw then on display sa blade. . One set has braided heatsink for around 5k++ while the other has fans ata for heat management, selling for approx 9k++.
Any inputs/feedbacks you may have sa philippine setting. Thanks
Ohhhh. . . Great. .. so heatsink lang talaga yun nasanlikod nun tig 9k ++
Promising ata kasi because of the brandname and the impression that more testing has come into the product and there's a hood(?) To prevent glare pag lowbeams
All the reviews that i've read came from other countries. . . Quite confident that it has way better visibility during fair weather driving. . . But nobody mentioned about visibility in the rain.
. And looking for more reliable inputs about highbeam throw.
Anybody?
Many drivers are installing LEDs especially with higher wattage (above 35w) and lumens (around 13,000+) and at 6,000 K. These are really bright, bluish white lights. The price ranges are from 4,500 to 6,000 pesos for some Chinese brands and for some branded ones, definitely pricier.
The downside is longevity. Most of my friends who tried LEDs do not really suggest to join the LED bandwagon since they experienced some product failure in less than 6 months. Mostly on the active ones or the ones with built in fans.
Narva H4 P43T-38 12V 60/55W Range Power 110
Better vision
Range Power 110
up to 110% more vision
The new Range Power 110 delivers 110% more vision. The powerful light beam allows drivers to see farther. A special burner design creates a higher lumen output for increased safety and greater performance.
Narva H4 P43T-38 12V 6/55W Range Power 11 | Lazada PH
Blade sells them at 1,299 a pair.![]()
