Results 21 to 30 of 152
April 28th, 2017 03:27 PM #21
^Instead of upgrading to 90/100w, you can try Philips X-treme Vision Plus or Osram Night Breaker Laser. Both are advertised as +130% more lights and both are perfect replacement 55/60w. Di mo kelangan magrelay/harness upgrade/ceramic socket.
- May 2012
- 372
April 28th, 2017 09:37 PM #22Thanks sir, i'll better check those items recommended.
Sent from my ASUS_T00I using Tsikot Forums mobile app
- Aug 2012
- 2,767
April 28th, 2017 10:36 PM #23Get Philips Xtreme Vision +130% if you can. It has longer life span, +200 hours more than Osram Night Breaker Laser +130%.
Sent from my ASUS_Z010D using Tapatalk
April 28th, 2017 10:44 PM #24
Paps KS Led or Keon Sondra is even much better than my HID... 13200lumens... compare to stock... it's night and day difference.. I got it for 5k... even the fog lights is impressive....
- Aug 2012
- 2,767
April 29th, 2017 06:52 AM #26If you want LED, there is also Philips ZES LED bulbs. H4 is 5k per pair. H11/H16 is 4k per pair.
April 29th, 2017 08:22 PM #27
April 30th, 2017 02:05 AM #28
- Aug 2012
- 2,767
April 30th, 2017 05:23 AM #29Keon Sondra is the name of the seller so he called his item "KS" LED. Actually, he is selling the same China made LED with Cree XHP-50 chip (9600 lumens) or XHP-70 chip (13200 lumens).
At 13200 lumens, ang worry ko lang dyan is yung mga kasalubong. It is good for offroad use though and pag solo mo ang kalsada.
- Aug 2012
- 2,767
April 30th, 2017 05:42 AM #30I settled with Philips ZES LED because I like the design of the bulb housing. At 8000 lumens, it is already brighter than my HID. My Osram CBI Xenarc D2S HID set is rated 6400 lumens.
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
