Results 11 to 20 of 152
March 26th, 2015 05:24 PM #11
kung magpapa LED or HID na headlights ba, kailangan na palagyan na relay? or kahit hindi na?
- Jun 2015
- 2
June 19th, 2015 08:20 PM #13Guys anyone tried comparing LED n HIDs? ano mas malakas? and masakit ba sa mata LEDs even naka low beam? sorry for a noob question. ty
- Mar 2014
- 901
April 13th, 2016 12:53 AM #14Parehas lang masakit sa mata o nakakasilaw, HID, lalo na LED. Kahit itutok mo pababa, kapag basa kalsada, ispalto o semento talbog rin yun ilaw sa kasalubong.
Sent from my UP+ using Tapatalk
- 54,205
April 13th, 2016 12:57 AM #15
- May 2012
- 372
April 28th, 2017 01:01 AM #16Question mga sir. May bad effect po ba ang 100/90 watts h4 bulb sa headlight housing? Sabi ng iba dapat daw nka ceramic socket kasi masyado mainit.
Sent from my ASUS_T00I using Tsikot Forums mobile app
April 28th, 2017 08:28 AM #17
Stock wiring and sockets are built to handle 60/55w only. If you're looking to upgrade your wattage, best to install a relay and change to ceramic sockets.
Sent from my SM-G930F using Tsikot Forums mobile app
- May 2012
- 372
April 28th, 2017 11:46 AM #18I see, thank you sir for that. So you mean i may still use the stock wiring but will have to install a relay to accommodate the power of 100/90 bulb?
- Jun 2005
- 3,774
April 28th, 2017 12:27 PM #19^when you use a relay, maglalagay ka na ng extra wiring circuit to handle the upgraded bulb wattage. Kaya ceramic na din ang socket dapat.
Bukod sa pwede matunaw ang wirings mo, mangingitim din amg headlight lens dahil mas mainit. Tignan mo yung mga taxi, usually vios gen2 na malabo at maitim headlights.
- May 2012
- 372
April 28th, 2017 03:19 PM #20Thanks for the input sir. I guess i'll stick to stock 60/55w.
My car is old 2000 ek civic,
Is there a way to modify? Or a thing to do lets say replace the old oem wiring with the aftermarket Narva headlight wiring thats being sold in ace or diy shops, will these improve the light output? Not to mention i'll have my headlight cleaned din pala.
Presence of mind should be the key in such situation, either quickly step on the brake or put the...
