Results 31 to 40 of 96
- Oct 2008
- 469
September 7th, 2009 03:17 PM #31Ask ko lang if, para sa mas brighter foglights ba, pag tigisahin ko ba relay? How much po ba range ng Bosch Relay ngayon?
September 7th, 2009 03:22 PM #32
- Oct 2008
- 469
September 7th, 2009 06:13 PM #33one is enough. any relay is good given it has the proper voltage and wattage capacity to avoid short circuits. might as well get a brighter pair of bulbs (higher wattage? form the stock) or a HID kit.
September 7th, 2009 11:40 PM #34
as i said one relay is enough considering that it has the right load capacity for what purpose you'll be needing it for.
might as well get a new set of plugs for your bulbs, i think the ceramic ones are more durable to withstand the heat and wattage load.
but beware, putting higher wattage bulbs might burn slowly your headlamps and can cause to blacken overtime.
- Oct 2008
- 469
- Sep 2008
- 24
September 13th, 2009 09:24 PM #36Sa akin e yellow sa fog lamps, headlights e ordinary H4.
Joseph20 .... OK lang po ang circuit ... yun ang gamit ko, so far e OK pa.
- Oct 2008
- 469
BANNED BANNED BANNED
- Sep 2009
- 14
September 17th, 2009 02:48 PM #38OK na yung yellow, all weather eh.. standard pa.. yung puti kasi nakakasilaw masyado.. parang nakakaabala pa nga sa mga driver na makakasalubong mo..
Tsikot Member Rank 3
- Jul 2004
- 1,540
September 17th, 2009 10:52 PM #39That's cheap. unless fake yan or 2nd hand? Are there fake polargs?
Cheapest i got was 3000 for H4 Yellow.
For me, not really worth the price you pay for it. If only HIDs have the same beam pattern as halogens, I would have opted to put HIDs.
Stick with eurolines if you want yellow bulbs. Almost the same lang ang buga
September 17th, 2009 11:23 PM #40
Firefox browser - :wonder: may error kapag mag attached ako ng piktyur sa computer ko insert image...
Problems with viewing Tsikot on non-Chromium...
